winch cable? - JeepForum.com
 9Likes
post #1 of 26 Old 06-27-2020, 01:01 PM Thread Starter
carlsflh
winch cable?
i've been looking at winches lately . what's better steel cable or Synthetic Rope i live in northern az and lots of sharp rocks everywhere .will the Synthetic Rope hold up to the rocks or will steel be better in this area . thanks
carlsflh is offline
post #2 of 26 Old 06-27-2020, 01:10 PM
04TJ-jeeper
04TJ-jeeper's Avatar
i prefer synthetic purely from a weight and safety perspective. it is (from my experience) more prone to damage, anything from rubbing against solid objects to spooling incorrectly. however as I mentioned the safety benefits far surpass that of steel. if you're worried about the chafing from rocks steel will also be damaged over time.
1987 YJ 4.2 / 1990 YJ 4.2 / 1995 YJ 4.0 / 2014 JKU / 2019 JLU
04TJ-jeeper is offline
post #3 of 26 Old 06-27-2020, 02:58 PM
92 Green YJ
92 Green YJ's Avatar
Another vote for synthetic. We have similar terrain here in SoCal and I’ve never had a rope break from rubbing the rocks. Personally I’ll never run steel cable again.
Synthetic rope is
Lighter
Easier to handle and work with
Safer (no risk of steel slivers in your hands, doesn’t store kinetic energy like cable does, if it breaks it will just drop to the ground instead of potentially slicing off a limb)
Pretty much any rope you get will come with an abrasion guard sleeve you can position on the rope if it does have to run near anything sharp.
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #4 of 26 Old 06-27-2020, 06:06 PM
timatoe
timatoe's Avatar
Synthetic for all the reasons listed above.
timatoe is online now
post #5 of 26 Old 06-28-2020, 05:29 AM
Waternut
Waternut's Avatar
Steel will hold to abuse and neglect a lot better but will obviously be more catastrophic when that abuse and neglect catches up. I have synthetic for the reasons above with weight and safety being the big ones for me.
One thing that hasn't been said... If your synthetic does rope break, you can splice it back together for the rest of the trip. It's compromised and weaker once you do that so don't consider it a long term solution but at least you can potentially still get yourself or someone else out of a jam. If a steel cable breaks, it's done.
IMO, you should have $15-$20 winch cover regardless so UV, rust, and road grime is irrelevant. It does amaze me how many people just leave their winch and rope sitting in the sun.
92 Green YJ likes this.
Waternut is offline
post #6 of 26 Old 06-28-2020, 05:55 AM
Cobra Jeep
Most synthetic lines come with a "sleeve" that you can slide up and down the cable to put up against rocks or other objects the line will rub. The "sleeve" will stay in place and let the cable slide through it, preventing damage.
I run synthetic as well. Weight and safety are the biggest reasons. If the synthetic line breaks and hits you, it will not be good, but it is not going to take a arm, leg, or head off like a steel cable would.
'93 YJ 4.6L stroker, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #7 of 26 Old 06-28-2020, 07:34 AM Thread Starter
carlsflh
thanks guys i was worried about rope getting cut/damaged on the rocks forgot about the sleves on the rope
carlsflh is offline
post #8 of 26 Old 06-28-2020, 07:43 AM
jsawduste
2006 YJ Wrangler
https://www.facebook.com/TacticalRecoveryEquipment/
https://tacticalrecoveryequipment.co...YaddAomvKXYKM8
Recovery equipment designed by wheelers for wheelers. Call and talk to Kristen and she will be happy to answer any questions you have.
jsawduste is offline
post #9 of 26 Old 07-02-2020, 08:48 AM
NHfireLJ
NHfireLJ's Avatar
Old canvas, fire hose, etc makes great chafing gear...
Remember too that synthetic is a woven line and the same size diameter syn compared to same size steel usually has a 3000-5000# higher BS... so even with a few chafed / worn fibers and you are still working with a stronger line than steel...
As posted above, love the TRE products, running a safety thimble myself
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #10 of 26 Old 07-02-2020, 10:00 AM
grandboost98
grandboost98's Avatar
Guess Ill be the odd man out.. I prefer steel cable over synthetic rope any day
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #11 of 26 Old 07-02-2020, 10:38 AM
bpounds
bpounds's Avatar
I would run synthetic, but I can't bring myself to throw away 125' of steel cable. Don't want it hanging around gathering dust either, and don't want to try to pack it as spare for a trail run. The winch spool makes a fine storage place for that cable.
So I think what I might do is buy the synthetic, and carry that for added length when needed to reach an anchor. Weighs little and takes up little space rolled up in a bag.
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #12 of 26 Old 07-02-2020, 11:06 AM
92 Green YJ
Gotta give us your reasons and arguments for steel cable and why you think it is superior to synthetic rope.
I always point out the Ultra4 cars and what they are all running at KOH. Haven’t seen a steel cable spooled up on one of their winches in years.
post #13 of 26 Old 07-02-2020, 11:39 AM
grandboost98
KOH rigs care about weight, I on the other hand could careless about weight. My whole frame is plated with 3/16" steel, my skids are all 1/4" steel. I choose ruggedness over lightweight. And Im not speeding through the desert at 90mph, I pretty much just do rocks. I rarely get out of 4low 2nd gear with the 4 banger
In my personal experience, I have seen multiple synthetic ropes fail from tears, rips, frays, etc. I have only seen one steel cable issue which could have been avoided and could have also happened with synthetic, they ran it out to far and it pulled off the drum. Again, just my personal experience over the past 12 years or so
Cable can just live through more abuse. When I actually have to use my winch, I don't want to worry about all the downfalls of synthetic. Just hook my cable up and pull. Im on my second cable now while some of the guys in my club have gone through several ropes
Actually just picked up another Warn with steel cable to put on my jeep and throw the old one on my trailer
post #14 of 26 Old 07-02-2020, 11:44 AM
Waternut
Waternut's Avatar
I thought this same thing and then one day I kinked my cable because I flipped the winch to free spool and the cable did what it always does and unwound itself into a birds nest. Only this time, I didn't need very much cable and apparently didn't get the birds nest out before tightening it back up.
Waternut is offline
post #15 of 26 Old 07-02-2020, 11:49 AM
grandboost98
Actually, If you carry a 0ga wire lug you can make a trail repair. Crimp/smash the lug on the broken end and spool it back up, assuming you have more than 15 feet or so and it will be just as strong, just shorter. Id trust that over a compromised spliced rope
