Whip lash - JeepForum.com
post #1 of 11 Old 05-04-2021, 11:02 AM Thread Starter
AWJ
Whip lash
1992 sahara manual has been driving great but all of a sudden has developed the cut out cut on condition while driving i pull over and the rpms bounce from around 6-just under 1k if i let it cool off it will run flawlessly until its up to temp usually 4 mins i can crank it at home and it will set there and idle i rev it up to about 2k every few mins and no problem it only cuts off and on while driving any thoughts or suggestions ?
AWJ is offline
post #2 of 11 Old 05-04-2021, 11:54 AM
Boojo35
1987 YJ Wrangler
I am not one to throw parts at a vehicle but....... replace the crank sensor.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #3 of 11 Old 05-04-2021, 12:09 PM Thread Starter
AWJ
The one in there is from napa and reads no resistance but thats not to say its not failing when up to temp what is the recomended one and where is the place to get it? Thanks
AWJ is offline
post #4 of 11 Old 05-04-2021, 12:44 PM
Boojo35
1987 YJ Wrangler
IIRC they are a hall effect switch which has a transistor. There is more to them than a resistance test. Honestly, NAPA stuff is usually decent for aftermarket type stuff but they do have different grades like NAPA performer to NAPA Echlin.
How new is your NAPA sensor that you do not want to condemn it?
It could be ASD or crappy wiring related, tired fuel pump, etc. but your symptom sounds like a crank sensor more often than not.
Boojo35 is offline
post #5 of 11 Old 05-04-2021, 04:49 PM Thread Starter
AWJ
It is a napa proformer and its about 3 months old the jeep itself was bought new by my dad and has never been off the road its been garage kept and is in great condition not to say that some wires and terminals may have corosion on them
AWJ is offline
post #6 of 11 Old 05-04-2021, 04:52 PM
Boojo35
1987 YJ Wrangler
So the Napa part may have a warranty on it.
Boojo35 is offline
post #7 of 11 Old 05-05-2021, 05:39 AM Thread Starter
AWJ
I will take the old one in when i go get a new one today
AWJ is offline
post #8 of 11 Old 05-05-2021, 09:09 AM Thread Starter
AWJ
So when i went to take the old one off the bolts weren't tight i could turn them with my fingers kids must have come outside during the last install and got me side tracked didn't have time to test drive but i tightened it up and it cranked faster than ever hope that was the problem
AWJ is offline
post #9 of 11 Old 05-05-2021, 10:01 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
I had a situation on a Cherokee we built. It would cut out, then high idle, then not start. It was a newer OBDII so we hooked up our Snap-on scanner to look at what was wrong. We could connect to the ECU, but the data kept disappearing and we had to re-start the vehicle, kill it, and the start reading again. We could not get a consistent connection for a running read either.
We assumed the ECU was borked and ordered a reman ECU. Once installed, the same issues happened.
From there I went through all of the ignition system checking for anything out of place. I visually inspected the coil and pulled the coil wire to replace the cables and noticed the two nuts that grounded and held the coil on were loose. I tightened them up, replaced the plug wires, and the issue went away forever.
We all miss things. I'm pretty sure a loose or floating CPS would cause the ECU to no know, at times, where the crank is and cause it to shut everything down to be safe.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #10 of 11 Old 05-05-2021, 04:55 PM
Boojo35
1987 YJ Wrangler
Boojo35 is offline
post #11 of 11 Old 05-09-2021, 08:00 AM Thread Starter
AWJ
Well tightening up the crank sensor didnt solve the problem
AWJ is offline
