where to find hood vent scoop - JeepForum.com
post #1 of 5 Old 02-14-2004, 10:32 PM Thread Starter
mudmann105
Guest
where can i find a hood vent scoop for a 94 tj, im sick and tired of water leaking into my cabin...please hlelp me.
-mudmann
mudmann105 is offline
post #2 of 5 Old 02-14-2004, 10:38 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
94 is a YJ bro
Quadratech or 4wd.com should carry them.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 5 Old 02-14-2004, 10:41 PM
92BlackandBlue
Do you already have one and are just having problems with it? If not, there are several listed in the Jeep Essentials catalog.
Bill
92BlackandBlue is offline
post #4 of 5 Old 02-14-2004, 11:15 PM
BuffaloYJ
BuffaloYJ's Avatar
-mudmann
Isn't there a water bypass tube (rubber hose "elephant trunk" looking thing in the engine compartment) that is supposed to stop water from leaking in? If water is your only concern (as opposed to getting better airlow in the cab) you may just wanna check to see that it's not plugged. Leaves and assorted gunk tend to block it up....
BuffaloYJ is offline
post #5 of 5 Old 02-15-2004, 06:56 AM
RCHavok797
RCHavok797's Avatar
The vent scoop is not a solution to your water leaking problem. Do what was already mentioned and check the rubber hose.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
Hood vent scoop ye or ne herculz TJ Wrangler Technical Forum 7 11-25-2009 02:10 PM
Anyone using the Vent Hood scoop over their heat and air grill? phillsam YJ Wrangler Technical Forum 16 03-02-2009 06:10 PM
Air vent intake hood scoop with filter? Rubikahn TJ Wrangler Technical Forum 15 08-06-2007 01:36 AM
hood vent scoop mic6 TJ Wrangler Technical Forum 26 12-01-2006 06:37 AM
Leaking Hood Vent needs Scoop bakwoodj2 YJ Wrangler Technical Forum 4 07-17-2005 10:38 AM
