when should the timing chain be changed - JeepForum.com
post #1 of 3 Old 02-06-2007, 12:24 PM Thread Starter
mlombardi
I just purchased a 94 yj with a 2.5 L . It has 137000 miles on it and I can't find info for mileage on the timing chain . Is it true the water pump should be changed at the same time?
mlombardi is offline
post #2 of 3 Old 02-06-2007, 12:44 PM
EABiker
A timing chain does not need scheduled replacement in the same way a timing belt does; the chain will not break; a belt can. If it runs OK then you probably have nothing to worry about. Ditto for the pump; if it is not leaking, no need to replace it. Save your $$$, its a Jeep, you'll need it soon enough!
EABiker is offline
post #3 of 3 Old 02-06-2007, 12:53 PM
martells2
Yep, I was confused and worried too coming from an audi as my previous car. Timing chain>timing belt...especially when it decides to snap when driving home at midnight from the city in the pouring rain and throwing all the rods into the block...that was a nice little $2000 mistake
Help Zach Beat Cancer
martells2 is offline
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
Changed timing chain... cha sha cha sha sounds back qbert213 TJ Wrangler Technical Forum 7 02-20-2008 06:33 AM
Timing chain in YJ 94 jeep_indika YJ Wrangler Technical Forum 2 01-05-2007 11:23 AM
Help On Timing Chain NYCjeep YJ Wrangler Technical Forum 1 02-01-2006 04:31 PM
Timing chain 93 Blue Demon YJ YJ Wrangler Technical Forum 0 03-18-2003 01:03 PM
