What's this part called? - JeepForum.com
post #1 of 8 Old 05-23-2020, 07:18 PM Thread Starter
Fishstic
Fishstic's Avatar
After Finally 2 years of working on my Jeep I've started the process of finally fixing the minor issues with it. One issue is that the passenger side door lock is missing a linkage that lets you lock with the key, I went on a Google spree but I couldn't find an exact name for it, couldn't find it on any aftermarket sites. (since I don't know the name)
Sent from my HD1907 using Tapatalk
Fishstic is offline
post #2 of 8 Old 05-23-2020, 07:43 PM
Chrisnvegas
Chrisnvegas's Avatar
Looks to be part of an assembly.
Even Chrysler didn't name each rod.
Most are marked as "rod" with a part number following.
https://parts.hendrickdodge.com/a/Je...E/WD87210.html
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #3 of 8 Old 05-23-2020, 08:48 PM
bruinjeeper
bruinjeeper's Avatar
lock cylinder "rod"?
door lock "rod"?
"rod" the lightning?
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #4 of 8 Old 05-28-2020, 01:24 PM
LJameson
LJameson's Avatar
It's a dikfer.
In all seriousnous, you'll probably have to go to a junkyard to find that part. They don't normally wear out or break, so nobody usually reproduces them.
1976 CJ7 Restoration:
LJameson is offline
post #5 of 8 Old 05-29-2020, 06:18 AM
Siva283
Siva283's Avatar
I would look for the plastic clips or an alternative. You can get a metal dowel in that size and bend it yourself with a vise or even vicegrips. The plasic retainers are going to be the hardest part however I bet there are tons of cars that use that clips and still do so it shouldnt be as hard to find
Ask me how I know...
Siva283 is offline
post #6 of 8 Old 05-29-2020, 10:06 AM
timatoe
timatoe's Avatar
Napa carries the plastic clips in a Dorman "Help" pack on the shelf, you can get GM, Ford or Chrysler specific or a multi-pack. I'd just a piece of rod and bend it as needed.
timatoe is offline
post #7 of 8 Old 05-29-2020, 12:19 PM
letitloose06
letitloose06's Avatar
The linkage rod is question is called "Lock Cylinder Rod". It's Jeep P/N 55026850 or 04797152, unfortunately it's NLA from Jeep. So you're gonna have to look for a used one on Ebay or a junk yard. You could also make your own. I measured a spare one I have laying around and it's 5/32" in diameter and 2.9" center to center.
The clips are P/N J4004532 or 04658677. These can still be purchased. If you can get OEM ones, do it. I've had bad luck with the longevity of the Dorman clips.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 Maxxis Bighorn MT's, Grizzly Locked 8.8 Rear, HP44 with Spartan, 4.10's, Smittybilt Armor, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
1951 CJ3A Restomod Project
letitloose06 is offline
post #8 of 8 Old 05-30-2020, 04:51 AM
fishadventure
fishadventure's Avatar
I’ve bought clips from CSEoffroad.com before. That’s the easy part
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
