What parts are worth robbing from an XJ? - JeepForum.com
 3Likes
  • 1 Post By bruinjeeper
  • 1 Post By timatoe
  • 1 Post By fishadventure
post #1 of 12 Old 10-11-2020, 01:19 PM Thread Starter
AcidRaiN
Junior Member
I have an 88 YJ with the 4.2L, BA-10 transmission,D30 front, and D35 rear.
I bought my daughter an 88 XJ pioneer Cherokee for us to fix up as her first car. As we were digging in, we quickly realized the entire truck needed to be re-wired. The PO must have cut and spliced every wire in the Jeep. I have it up for sale as a project, but are there parts I can use off the XJ for my YJ?
I think the XJ has the hp d30. Maybe trade her automatic transmission and replace the ba10 with it. Keep the 4.0 head to build up the 4.2? Possibly her steering column if it has tilt.
Thoughts? Any other parts I could use?
Thanks!
Sent from my iPhone using Tapatalk
AcidRaiN is online now
post #2 of 12 Old 10-11-2020, 02:04 PM
4Low2G0
4Low2G0's Avatar
Pull the engine, transfer case, rear axle, ECU and engine harness keep them for the YJ.
I'd sell parts off the shell and sell the trans, to do an AX15 swap on the YJ not go auto, .
Wheels/tires if they're nice
Maybe the front axle, all the mounts will be wrong, but it could be used for spare parts or sold.
With the 4.0 and the 4.2 you can build a stroker
Whats over that next ridge?
4Low2G0 is online now
post #3 of 12 Old 10-12-2020, 05:36 AM
fishadventure
fishadventure's Avatar
In addition to above:
The ebrake lever can be used to get rid of the pedal parking brake if that appeals to you. Keep the D30 and CV driveshaft, too. Sell the ECU. Junk the XJ. Save the air filter box as it is modifiable for other YJ applications but is hard to obtain sometimes.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 12 Old 10-12-2020, 11:59 AM Thread Starter
AcidRaiN
Junior Member
That's what I was thinking. I'm having trouble finding how to swap a HP Dana 30 into the YJ. I'm also thinking of grabbing the NP231 transfer case to have a spare to rebuild and install a SYE on while I still drive the jeep.
Is there a way to add the air filter to my carbureted 4.2?
Thanks!
post #5 of 12 Old 10-12-2020, 12:17 PM
metalry101
metalry101's Avatar
Thanks!
YJ's already have HP Dana 30's from the factory.
If memory serves correctly, swapping t-cases might be a problem. Since they're both 6 cylinders, I think they're the same spline count, but I think I've read that YJ and XJ t-cases are clocked about 10 degrees differently. That's not a ton, but I assume they did it for a reason. You'll want to look into that. All the internals otherwise should be fine, so you could keep it as a spare.
'90 YJ - Squirrel powered and on 35's!
Utah Jeepcrew #26
metalry101 is offline
post #6 of 12 Old 10-12-2020, 12:55 PM
bruinjeeper
bruinjeeper's Avatar
A/C compressor if equipped
danthman likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #7 of 12 Old 10-12-2020, 02:07 PM
4Low2G0
4Low2G0's Avatar
They are clocked slightly different, but people drill the adapter to correct this, easy fix.
post #8 of 12 Old 10-12-2020, 02:11 PM
timatoe
timatoe's Avatar
That XJ likely has the Renix 4.0 and LP D30, I wouldn't keep anything. You'll get more parting it out, but that's also a headache. "Project" XJ's around here might bring $600 and this is a place where a YJ hardtop will fetch $1,400.
AcidRaiN likes this.
timatoe is offline
post #9 of 12 Old 10-16-2020, 06:19 AM
fishadventure
Forgot about that!!
Do the LP D30s have different axles? But the again did those earlier XJs not have the one-piece R axle shaft? (CAD instead?)
post #10 of 12 Old 10-16-2020, 07:37 PM
timatoe
timatoe's Avatar
Shafts are the same, early XJ's used the CAD as well I believe. I picked up a complete XJ D30 with a busted knuckle for $50 to get the shafts and steering components when I still had a D30.
timatoe is offline
post #11 of 12 Old 10-17-2020, 08:09 AM Thread Starter
AcidRaiN
Junior Member
Doesnt sound like there is much worth keeping. Im just going to sell it as to get it out of here. Ive already got a new car lined up for my daughter. 2003 Tahoe in really good shape. Plus a good deal. Cant pass it up.
She does have the benefit of helping me on the YJ, so she will still learn and keep her out of trouble. Lol
post #12 of 12 Old 10-17-2020, 08:32 AM
fishadventure
Doesn’t sound like there is much worth keeping.
There is whole bunch of things people listed above.
\confused/
bruinjeeper likes this.
