What to look for in a waggy? - JeepForum.com
post #1 of 3 Old 04-10-2007, 11:36 AM Thread Starter
Dave_L
Guest
I'm looking to pick up some D44's from a wagoneer but I'm wonder what to look for when inspecting the axles. Are there some year waggy's that are a little more desireable than the others? Or ones that make the swap a little easier? I've found some cheap non-running waggy's but just trying to get some more info on what to look for and what to avoid. I've found an '87 and '88 for around $500, non-running.
I also have an opportunity to pick up a '78 f-250 for decently cheap. It has the D60 in the rear and d44 up front, 4.10 gears and disc brakes. Would this work a little better? The price on this one is about $1500 but the truck runs great so I could part everything else out.
I plan on just getting some axles ready for when I go SOA. Just trying to piece everything together so I can do it this winter. I don't plan on running tires larger than 37" and it'll be going on my '94.
Dave_L is offline
post #2 of 3 Old 04-10-2007, 11:44 AM
bayvilleYJ
Guest
If you are gonna run 37's or bigger then the waggy's are out. Go with the 60 and 44. I just did the same swap , just have to move the perches and hook up steering and brakes. I'm running 39x 18 mickeys.
bayvilleYJ is offline
post #3 of 3 Old 04-10-2007, 11:56 AM
XJtheTanK
x2 on the ford 250
XJtheTanK is offline
Waggy 44 into tj/yj Solidkm TJ Wrangler Technical Forum 89 01-07-2010 09:14 AM
HP 30 or Waggy 44 goldswim5 TJ Wrangler Technical Forum 14 10-04-2009 10:17 PM
81 waggy SASKJEEPER YJ Wrangler Technical Forum 1 05-03-2008 10:35 PM
HP D44 right? 85 Waggy jeepjared84 YJ Wrangler Technical Forum 2 04-29-2007 07:03 AM
waggy 44, isuzu 12 bolt, waggy leaves (sua), tj flares mississippi_xj YJ Wrangler Technical Forum 6 12-08-2005 07:18 AM
