What is a heated backlight and do I need it? - JeepForum.com
post #1 of 8 Old 01-06-2018, 10:41 AM Thread Starter
mikwallace
mikwallace's Avatar
Iím in the process of removing oem MCU and any associated wiring not required. Iíll add the Performance Fuel Injection Systems TBI conversion with MCU. During this process Iíve made an attempt to trace every wire and using the FSM determine which wires I want to keep, even if from old system, to adapt to future use. Iíve run across a wire:
-Brown/with white tracer
-Bulkhead Connector A5
-Labeled Heated Backlight
What is ďHeated BacklightĒ?
Do I need it?
Thanks!
Hereís a picture of what Iíve pulled out thus far!
And whatís remaining!
Sent from my iPhone using Tapatalk
mikwallace is offline
post #2 of 8 Old 01-06-2018, 11:47 AM
timatoe
timatoe's Avatar
No idea about a heated backlight. You sure it's not the manifold heater?
timatoe is offline
post #3 of 8 Old 01-06-2018, 12:09 PM Thread Starter
mikwallace
mikwallace's Avatar
No, I'm not sure, but don't think it is the manifold heater. It's a brown w/white tracer wire that goes from the bulkhead connector (engine harness side) to the 1"x2" diode circuit board next to the diagnosis connectors. I can't remember the purpose of diode board? The FSM says "heated backlight".
post #4 of 8 Old 01-06-2018, 12:21 PM
fishadventure
fishadventure's Avatar
heateR backlight? Maybe a tiny typo?
Or a BIG typo and the whole phrase is whacked.
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is online now
post #5 of 8 Old 01-06-2018, 12:26 PM Thread Starter
mikwallace
mikwallace's Avatar
Well, I found this info about the diode board:
https://www.jeepforum.com/forum/f12/p...y-tray-939460/
It appears I don't need the board, just gotta trace the br/wh wire inside the cabin and see if I can use it for something else.
post #6 of 8 Old 01-06-2018, 03:00 PM
crackedcornish
crackedcornish's Avatar
heated backlight = rear window defroster
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #7 of 8 Old 01-06-2018, 03:06 PM Thread Starter
mikwallace
mikwallace's Avatar
Yep!! Just found it too!! The br/wh wire comes from diode board next to-diagnostic port to bulkhead then through firewall to rear window defogger relay ( of which I donít have) then to harness through switch to rear window.
FSM, electrical, page 8W-136&137.
This FSM is great!!!
Thanks for the help!!
post #8 of 8 Old 01-06-2018, 08:12 PM
timatoe
timatoe's Avatar
Hmm, interesting. I pulled all of that stuff out by the diagnostic ports when I went FI. (except the manifold heater relay)
timatoe is offline
