What is this that fell out of my rear output shaft? - JeepForum.com
 1Likes
  • 1 Post By Boojo35
post #1 of 11 Old 07-24-2021, 05:47 PM Thread Starter
Captainjz16
Captainjz16's Avatar
While replacing the rear output shaft seal, this fell out. What is it? I don't see the rest of it.
I was replacing a recently installed seal as it kept leaking even after the install. I have a new slip yoke too, but was surprised to find this inside.
Captainjz16 is offline
post #2 of 11 Old 07-24-2021, 06:18 PM
Boojo35
1987 YJ Wrangler
That is about half of a retaining clip for a u Joint cap
Luuca likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #3 of 11 Old 07-24-2021, 09:12 PM
Awesome
Awesome's Avatar
If it was inside the transfer case then it's one of the c-clip retainer things on the output shaft. Or half of it, at least. Hard to tell how big it is in your picture.
The 4th 5-seater YJ in the world.
Awesome is offline
post #4 of 11 Old 07-25-2021, 05:59 AM
Cobra Jeep
Yep, that looks like one of the locking rings from inside the transfer case. They are used to hold the bearings onto the shafts.
Remove the rear tail housing from your transfer case and see if it is the one that holds the rear bearing to the shaft.
'93 YJ 4.6L stroker, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #5 of 11 Old 07-25-2021, 06:13 AM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
I'm with Awesome and Cobra on this one.
Considering your recent issue, i guess that it is indeed from within the transfer case (without knowing the size scale).
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #6 of 11 Old 07-25-2021, 09:23 AM Thread Starter
Captainjz16
Here a photo of the size. I'm going to drop the housing and see what's going on.
post #7 of 11 Old 07-25-2021, 02:00 PM
bruinjeeper
now that you're gonna be in there that deep . . . . you might as well .........
post #8 of 11 Old 07-25-2021, 02:24 PM
Awesome
Awesome's Avatar
1-5/16"? Yeah definitely a bearing/gear retainer clip from the output shaft on the transfer case. Pulling the tailhousing off won't really help you, you're going to have to split the case.
Awesome is offline
post #9 of 11 Old 07-25-2021, 04:46 PM Thread Starter
Captainjz16
Why not? I took the housing off and it looks like it goes on the outside of the bearings. There appears no way for it to have come from behind the bearings and inside the transfer case.
I'm assuming when i took off the seal, the oil running down carried it out.
post #10 of 11 Old 07-25-2021, 05:17 PM Thread Starter
Captainjz16
Here's a photo of the ring that broke/is missing.
post #11 of 11 Old 07-25-2021, 09:42 PM
Awesome
Awesome's Avatar
Oh right, I forgot the factory output shaft has one there.
Awesome is offline
