Water leak into cab. - JeepForum.com
post #1 of 5 Old 06-02-2020, 03:49 PM Thread Starter
Mercenary911
Hi folks. My 95 YJ has developed a water leak into the cab. It only shows up on the passenger side footwell. I initially thought it was coolant from the heater core but it doesn't look or smell like coolant. I'm thinking it might be from the cowl vent. If the drain tube is blocked will that cause water to come into the cab on the passenger side?
Mercenary911 is offline
post #2 of 5 Old 06-02-2020, 03:53 PM
jkbrereton
Could be. That would make sense if you are sure it's not coolant. Regardless, you probably are looking at removing the duct work and opening it up
Sent from my Pixel 2 XL using Tapatalk
jkbrereton is offline
post #3 of 5 Old 06-02-2020, 05:40 PM
Boojo35
1987 YJ Wrangler
The drain tube is out by the firewall and easy to access from the engine bay. The bottom of it is a flat slit type opening to deter rodents and such from being able to climb up into it. Squeeze it to make it round and see if there is debris in it. To water test it, pour water into the cowl vent only. The rubber seal under the windshield frame can be a leak. The body seam a few inches below that can be the leak. The windshield can be the leak and so can the top and front corners of the doors just to name a few.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #4 of 5 Old 06-03-2020, 01:34 AM
timatoe
timatoe's Avatar
There's a thread on testing different spots for leaks in the Frequently Asked Questions.
timatoe is offline
post #5 of 5 Old 06-04-2020, 07:40 AM
FergiesJeep
I had the same with mine it turned out to be the cowl seal. easy replacement.
FergiesJeep is offline
