Waggy front parts list - JeepForum.com
 1Likes
post #1 of 29 Old 01-15-2020, 09:53 PM Thread Starter
brianfulcher15
Hey guys,
Does anyone have a line to the parts i need to get a waggy front axle setup to support a high steer setup and also have a 5x5.5 bolt pattern.
I searched and everything i found had bad links or seemed to not be that clear.
Im wanting to just be able to buy what i need on rock auto if possible.
Also is there a setup that would allow me to run sua for a bit and support adding a high steer arm? For when i go soa?
Sent from my Pixel 3 XL using Tapatalk
1"body lift,1"shackle lift,2.5"spring lift
Flat cut fenders,4.0 auto, smitty rear bumper,35x12.5
brianfulcher15 is offline
post #2 of 29 Old 01-15-2020, 09:59 PM
paulhead
if it works fix it
paulhead's Avatar
https://www.pirate4x4.com/tech/billa...ngresearch.htm
http://www.billavista.com/tech/Artic...xle/index.html
Trying to weld has honed my grinding skills
paulhead is offline
post #3 of 29 Old 01-15-2020, 10:02 PM
paulhead
if it works fix it
paulhead's Avatar
Just go SOA from the start and save money. I broke my bank doing what you're thinking.
paulhead is offline
post #4 of 29 Old 01-15-2020, 10:50 PM Thread Starter
brianfulcher15
I well that is the real goal i was more just asking if it was simple to make it work with the same thing because im 4-6 months away from going soa.
Thanks for the links ill take a look at those.
paulhead likes this.
post #5 of 29 Old 01-16-2020, 04:57 AM
jkbrereton
It's been a while since doing mine but Parts Mike Parts had the flat top knuckles, high steer arms, and some other stuff as I recall. He would mill and drill the knuckles as well
Sent from my Pixel 2 XL using Tapatalk
jkbrereton is offline
post #6 of 29 Old 01-16-2020, 04:59 AM Thread Starter
brianfulcher15
Ok so if im reading all this right i need
A small bearing spindle from a gm
Should be this guy
https://www.rockauto.com/en/parts/da...+bearing,10498
A 79 bronco rotor, hub and warn hub selector
I reuse the waggy brakes just rebuild them
What year chevy knuckle do i use to get the flattop and does any one sell these machined?
Am i missing anything?
post #7 of 29 Old 01-16-2020, 05:45 AM Thread Starter
brianfulcher15
Are these the correct knuckles?
https://rover.ebay.com/rover/0/0/0?m...2F282826197217
post #8 of 29 Old 01-16-2020, 06:10 AM
paulhead
if it works fix it
paulhead's Avatar
I just did this on an F250 D44, I may have some numbers listed too. https://www.jeepforum.com/forum/f12/...l#post40502353
paulhead is offline
post #9 of 29 Old 01-16-2020, 06:54 AM Thread Starter
brianfulcher15
do I need a different backing plate for the GM spindle to bolt into or does it work with what comes with the wagoneer axle
post #10 of 29 Old 01-16-2020, 07:18 AM Thread Starter
brianfulcher15
Also was wondering if i will be able to run these with rcvs
post #11 of 29 Old 01-17-2020, 06:53 AM Thread Starter
brianfulcher15
So when I'm looking at some of the knuckles that are already machine that's over on parts Mike and then the ones like the East coast or selling they all say that their machine for a CJ. is there any difference in the machine work done on those and the work that you would have done to put these on to a YJ. I think I might pull the trigger on one of these set since when looking at the cost of getting used knuckles and pay him for the machine work and then buying arms only about 50 bucks away from just buying the set from these guys but I want to make sure that there's no change in the angles or something on the machine work on cj vs yj before I buy them.
post #12 of 29 Old 01-17-2020, 07:00 AM
jkbrereton
I can't see why there would be a difference.
post #13 of 29 Old 01-17-2020, 07:31 AM
jsawduste
2006 YJ Wrangler
Do yourself a favor and purchase a set of Reid Ford knuckles. That way you can buy a complete F150 outers. Rather than try to mix and match parts hoping it will all play nice together.
One thing about the Ford Reid`s is that they are based on the Bronco wheelbase rather than a typically longer WB pickup. Meaning the Ackerman is much better suited for our YJ`s. End result is a much better handling vehicle.
Drag link to a high steer arm on the passenger knuckle and the tie rod to the cast arms on the knuckle itself.
There are no high steer arms that will preserve any semblance of Ackerman available. You want the Ackerman and the resulting steering geometry for a good handling rig.
Plus if you ever find a set of 78/79 F250 brake caliper brackets you can switch over to the F250 1 ton dual piston calipers and larger rotor from a Dodge 150 and still keep your 5 on 5.5 bolt pattern.
I ran this setup for a number of years. It worked very well even without a steering dampener. That said the 2 pictures do show a PSC ram however I did run without anything for a season.
jsawduste is offline
post #14 of 29 Old 01-17-2020, 07:40 AM
jsawduste
2006 YJ Wrangler
IF you cannot find the Ford caliper brackets than do the same set up with the Chevy/Waggy Reids. You wont be able to run the bigger 1 ton caliper from a Ford though.
The links the Paul provided show you how to mate the DL and TR but Bill Vista doesn't say anything about steering geometry. Other that keeping the DL to BJ distance the same as the Pitman arm.
Parts Mike sells a non keyed arm that can be machined to whatever you want. Plus it adds steering angle to the right. If you look at the stock arm you see it isn't clocked straight.
post #15 of 29 Old 01-17-2020, 09:03 PM
TSEJEEPERS
TSEJEEPERS's Avatar
I was able to use the Waggy backing plate and calipers.
Chevy spindle and Ford hub, rotor and lock out.
I do not remember what flat top knuckles I got though.
I want to say they were early Jeep.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
