I am wanting clean up all the vacuum system stuff i don't need on my 87 4.2 yj. I live in Oklahoma and we don't have to pass smog so I'm not worried about the emissions stuff. I have included a diagram of the system and would really appreciate guidance on what stuff can be removed.
Thanks for the pic Drednot. I stumbled by this thread a little late but I plan on replacing the vacuum lines to my 4.2 when we are reunited. Now I know which ones I need and which ones the PO stuck on random places to look like they were doing something. When I get really ambitious I will attack all the extra wires.
This is actually really easy. I just did it the other weak. Tossed all emissions stuff and all extra lines. Nuttered and now things are clean and running good. Just follow line by line and take your time.
I got all the stuff i didn't need disconnected and will remove all the stuff this weekend. Two things I found in the process that I was wondering about.
Should the rear valve cover breather/ pvc valve grommet have a breather or CCV valve in it? not sure if this is correct but it sounds to me like a ccv valve works the opposite of the PCV valve.
secondly, is the evap canister worth keeping or should I remove it too?
The rear of the valve cover should have a breather. Stock, it runs to the bottom of the air cleaner.
Keep the evap canister. There is no benefit to removing it other than to make it pollute more. It will smell like gas if you do remove.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
