Underhood Light Problem - JeepForum.com
post #1 of 17 Old 08-13-2019, 06:21 PM Thread Starter
Robort
Robort's Avatar
I put a bulb in my underhood light socket and it works how do you turn it off (stays on with hood closed) 1995 yj
Robort is offline
post #2 of 17 Old 08-13-2019, 06:23 PM
bruinjeeper
bruinjeeper's Avatar
it should shut off automatically... as i believe there is something that acts as a 'gravity switch' of sorts.
try some non abrasive sensor cleaner in there and try prodding at the components a bit.
EDIT: wait, were you using it normally recently or was the bulb missing for a while and you finally just decided to add a bulb? if the latter, some corosion may have built up and i'd just mildly clean it and prod into it. Perhaps a new fixture is in order.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #3 of 17 Old 08-13-2019, 06:30 PM Thread Starter
Robort
Robort's Avatar
i put a piece of copper inside the socket to make it work i bet it had a ball bearing that rolled back and forth
Robort is offline
post #4 of 17 Old 08-13-2019, 06:35 PM Thread Starter
Robort
Robort's Avatar
yup thats it put a slingshot ball inside it and it worked thanks
Robort is offline
post #5 of 17 Old 08-13-2019, 07:50 PM
bruinjeeper
Yup. No problem.
Glad you sorted it. I should probably hook mine back up. What bulb part # did you find? And is it off the shelf at a local auto store?
post #6 of 17 Old 08-14-2019, 06:25 AM
Siva283
Siva283's Avatar
Originally Posted by bruinjeeper View Post
Yup. No problem.
I can tell you its not an 1157 or 2157 lol I to am curious as to what bulb fits it.
Ask me how I know...
Siva283 is offline
post #7 of 17 Old 08-14-2019, 06:54 AM
mudbug85603
mudbug85603's Avatar
Originally Posted by Robort View Post
Yup, that's it I put a slingshot ball inside it and it worked thanks
So it just rolls around in there? What happens when it's parked on an uphill grade? Does the light stay on? rough road does the light constantly go on and off? It seems like a bad design... I would think a plunger switch like what the doors use for courtesy lights would be a better idea. Neither of my Jeeps have a hood light, I carry a flashlight for that and many other reasons.
'98 TJ 5sp Super 35 D30 w/Aussie 5.13 on 33's
'94 YJ 5sp 4.88 Super 35/HP30 w/Aussie on 33's
mudbug85603 is offline
post #8 of 17 Old 08-14-2019, 06:58 AM
bruinjeeper
Agreed
Now you got the hamsters in my head running. Hmmm.
post #9 of 17 Old 08-14-2019, 08:28 AM
Siva283
Siva283's Avatar
Agreed
I always thought they were a mecury switch kinda like a thermostat. I think I am gonna put some LED's under there in various places so a flashlight wont be needed and all areas will be lit in the dark. I also think I will just hook them up to an outdoor rated toggle switch mounted by the battery. Then they are only on when I need them and not draining the battery if I pop the hood during the day or if I want the hood open at night for some reason but dont need the light.
The stock light seems like it would be pretty useless even if it did work anyway
Siva283 is offline
post #10 of 17 Old 08-14-2019, 09:18 AM
Boojo35
1987 YJ Wrangler
They are gravity for sure but I dont remember exactly how they did it. How they are bent on the bracket affects their operation though. We used to bend them down in GM cars to shut the hood light off while we worked on them.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #11 of 17 Old 08-16-2019, 07:55 PM
TSEJEEPERS
TSEJEEPERS's Avatar
My bulb burned out years ago and I did not replace it but, It seems to me that the under hood light was controlled by the dash light/ interior light dimmer switch.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 17 Old 08-17-2019, 07:45 AM Thread Starter
Robort
Robort's Avatar
I got an old bulb off my neighbour. single filament and the bumps on the side are the same distance from the end of the bulb not offset like a dual filament bulb. You would have to be parked on a pretty good hill to roll the ball up to make contact. the switch is tilted down a fair amount. If the light goes on and off on a bumpy road it will give a cool lightning affect at night and im ok with it.
Robort is offline
post #13 of 17 Old 01-26-2020, 06:33 AM
leafman60
Any more info on this? What bulb type. Manual says 105 bulb. According to research, this has a BA15S base. The manual says the lamp socket is an automatic thing with a non-specified "fluid."
******* EDIT UPDATE *********
Okay, I just removed my lamp assembly as per manual. This is not for a 105 BA15S bulb. It is a simple 1156 socket for an 1156 bulb.
leafman60 is offline
post #14 of 17 Old 01-28-2020, 06:42 PM
leafman60
And, there's more.
I cleaned up my lamp socket with a small Dremel wire brush and put everything back together with a new 1156 bulb wiped down with contact grease. Wow, that thing puts out a lot of light. It does a good job of lighting the engine compartment at night - and it does go out when the hood is closed.
(To remove the bulb assembly, you take out the bulb and remove the screw that holds everything to the hood. The socket comes apart by gently releasing the side catches on the wiring harness. Watch out for the bullet-shaped contactor that will fall out.)
My main worry is about the aged plastic reflector around the bulb and the damage that the bulb's heat may cause to it. I'm going to look into a LED version of the 1156 to avoid that heat of a standard incandescent bulb.
post #15 of 17 Old 01-28-2020, 09:35 PM
Awesome
Awesome's Avatar
I tried making my own bullet-shaped contactor out of a.... bullet. It didn't work. Won't slide smoothly enough. Not sure what else I can use. Tried a small steel ball and that didn't work. Might have been too small.
The 4th 5-seater YJ in the world.
Awesome is offline
