Under dash wiring connector - JeepForum.com
 1Likes
  • 1 Post By Awesome
post #1 of 13 Old 04-05-2020, 03:24 PM Thread Starter
JohnW63
In my other thread, about dogs and squirrels I was having trouble with a few electrical things. Well, I was under the dash, and found all the old alarm system stuff that was put in there, shortly after we bought the Jeep in 1992. I realized they had a connection device that went between the two stock connectors and other splices and junk under there. I pulled it all out, trying to make sure I removed stuff that did not look stock.
I have this connector that I was going to plug back together, now that the third party junk was gone, but I see that there is one less wire on one plug than the other side.
You can see there are 4 wires on the right side of each plug and three on the left side of the top plug, but only two on the left side bottom plug. I'm checking out the service manual to see if the missing wire was not there , since day one, or if the alarm guys removed it and used it. If anyone is familiar with this plug, and knows a thing or two, let me know. The manual has the full wire diagrams, but the page with the flashers don't show the connector clearly.
JohnW63 is offline
post #2 of 13 Old 04-05-2020, 04:08 PM
Awesome
Awesome's Avatar
The original alarm systems for the Jeep were part of the windshield wiper relay. You can unplug the alarm wires from the box, but if you want to keep your intermittent wipers you need to leave the other wires plugged into the box.
timatoe likes this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #3 of 13 Old 04-05-2020, 05:38 PM Thread Starter
JohnW63
It was a third party alarm install. Our Jeep did not come with an alarm. Base model and soft top.
JohnW63 is offline
post #4 of 13 Old 04-05-2020, 07:08 PM Thread Starter
JohnW63
Do you mean THIS box ?
That was what was velcro'd to a sheet metal plate that the alarm guys put in.
JohnW63 is offline
post #5 of 13 Old 04-05-2020, 07:31 PM
Awesome
Awesome's Avatar
See my first reply.
They were a dealer-install option. I'm sure some aftermarket shops had access to them as well.
Awesome is offline
post #6 of 13 Old 04-05-2020, 07:32 PM
timatoe
timatoe's Avatar
Yep, that's where it's supposed to be. It's the wiper delay box, put it back where it was and plug both sides of that connector to it. If not you'll only have two wiper speeds and no delay.
Good thing to know is if your wipers ever just crap out all together, you can pull that box, reconnect the two plugs and likely at least get them working with no delay.
timatoe is offline
post #7 of 13 Old 04-05-2020, 07:47 PM Thread Starter
JohnW63
The sheet metal looked like a quick install and had a toggle switch sticking out of it.
If having it causes no harm, I'll put it back. I'm trying to trouble shoot why the wipers come on as soon as the key is on and will not shut off. The two speeds worked, but I'm not sure the intermittent part did. I have no turn signals either, and that's why I thought this old alarm might be the problem, since it was probably supposed to flash the lights when it went off.
JohnW63 is offline
post #8 of 13 Old 04-05-2020, 07:50 PM
Awesome
Awesome's Avatar
Come to think of it, the alarm isn't contained in the wiper module, it just plugs into it. I think I finally removed my alarm box because I got tired of it falling on my feet.
Huh.
Okay, well the alarm box looks very similar to the wiper box, and has a connector that is very similar to the wiper box. Mine had blue and red wires twisted together.
Awesome is offline
post #9 of 13 Old 04-05-2020, 07:55 PM
timatoe
timatoe's Avatar
Quite possible the delay box is bad, best bet there is find a Cherokee in a Pick-n-Pull and pull it.
But..... I'd suspect the multi-function switch in the column base on both issues mentioned.
timatoe is offline
post #10 of 13 Old 04-05-2020, 09:36 PM Thread Starter
JohnW63
Timatoe,
I suspected the multi-function switch at first, but the wipers come on with the wires to the steering column unplugged.
Did the Cherokee have the same box as the Wrangler ? What years should I look for ?
To circle back to the beginning, can I just plug the wires together without the box to verify the issue is in the box ? Is there not supposed to be another wire, not shown in my pictures ? I don't see a plug for one in the slot, but the opposite plug HAS a wire there.
JohnW63 is offline
post #11 of 13 Old 04-06-2020, 06:22 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Yes you can plug the connectors together. It will delete the wiper delay.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 13 Old 04-06-2020, 09:17 AM
timatoe
timatoe's Avatar
Originally Posted by JohnW63 View Post
Timatoe,
Yes the box is the same. Don't have a year range, but any of the square body Cherokees with that box under the dash...
Yes, the plugs will just go together and eliminate the box.
timatoe is offline
post #13 of 13 Old 04-11-2020, 07:54 PM Thread Starter
JohnW63
Removing the box makes the wipers work properly , but with no intermittent function. So, I have a possible bad box. I still worry that too much rain and weather got in the Jeep and the stalk still could have an issue that removing the box bypasses. I'm going to try and find a box and find out. Now, I need to make the turn signals work. It seems like that would be simple. Power goes through blinker, goes through the wires to steering column, the lever moves one contact or the other in the circuit and the blinkers on that side blink. The Hazard switch can be in the mix, if it is activated.
JohnW63 is offline
