two loose connectors under the hood - JeepForum.com
 2Likes
  • 1 Post By timatoe
  • 1 Post By LJameson
post #1 of 11 Old 06-01-2020, 06:44 PM Thread Starter
oryj94
Hey, just picked up this 94 YJ project. Found two connectors not going anywhere near the alternator. Anyone know where these are supposed to connect to? Maybe a different type of alternator?
First pic shows the two wire connector sitting on top of the alternator bracket. The other connector in the third pic has just one blue wire.
IMG_20200601_160549800.jpg   IMG_20200601_160608519.jpg   IMG_20200601_163955920.jpg
oryj94 is offline
post #2 of 11 Old 06-01-2020, 08:10 PM
jbolty
jbolty's Avatar
harness for a/c maybe? the dry and pressure switch would be on the fender if it was installed
jbolty is offline
post #3 of 11 Old 06-01-2020, 10:06 PM Thread Starter
oryj94
All the gauges work and this Jeep doesn't have AC. Wonder if it was an optional plug for something. Looks factory though. They were just kinda flopping around when I found it. Here's one more pic I highlighted where it branches out of a bigger wiring conduit.
oryj94 is offline
post #4 of 11 Old 06-01-2020, 10:09 PM
92 Green YJ
92 Green YJ's Avatar
Well the AC compressor would sit on that bracket above the alternator. I’m pretty sure Jeep wired the, for AC even if they did not have it installed. I would also say it is for the AC.
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #5 of 11 Old 06-02-2020, 03:33 AM
timatoe
timatoe's Avatar
They all came wired the same whether it had A/C or not. I'd say A/C as well based on location.
Awesome likes this.
timatoe is offline
post #6 of 11 Old 06-03-2020, 12:28 PM Thread Starter
oryj94
Thanks, gonna go with ac plug and just tie it off.
oryj94 is offline
post #7 of 11 Old 06-03-2020, 04:02 PM
LenVino
The two-prong connector with the blue center looks like a fog light plug. Check the driver side for a similar plug. A/C plug is usually round with three cavities. The one you outlined in red could be a ground cable that may have been attached near the dipstick Might wanna double check that. Either way, please post back and let us know what you find.
LenVino is offline
post #8 of 11 Old 06-04-2020, 04:48 AM
fishadventure
fishadventure's Avatar
Without looking further I could be wrong. But is that 2-wire connector for the temp sender on the thermostat housing?
If not it may be AC clutch and therefore a nice way to turn on/off onboard air compressor....
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #9 of 11 Old 06-04-2020, 08:20 AM
LJameson
LJameson's Avatar
When I installed the JeepAir kit on my YJ, I used the factory plugs for the system on the 94 harness I installed. Jbolty is right, the two prong connector goes to the A/c pressure switch, while the single prong is for the A/C compressor clutch.
NHfireLJ likes this.
1976 CJ7 Restoration:
LJameson is offline
post #10 of 11 Old 06-04-2020, 11:39 AM
LenVino
Guess I was wrong..
LenVino is offline
post #11 of 11 Old 06-05-2020, 06:07 PM
fishadventure
Excellent response. Thank you.
