the turtle - JeepForum.com
 3Likes
post #1 of 19 Old 08-02-2021, 05:36 AM Thread Starter
djm609
the turtle
i have a 95 yj with the 2.5 it will not go over 50 mph. what is going on
Always wrenching
djm609 is offline
post #2 of 19 Old 08-02-2021, 06:22 AM
gutthans
gutthans's Avatar
Take it out of first gear?
Really, a little more detail type stuff would be helpful here...
JD Blaine likes this.
gutthans is offline
post #3 of 19 Old 08-02-2021, 06:50 AM
cas6969
cas6969's Avatar
How big are your tires?
5 speed? With mine, when I first started driving it, probably the first 6-8 months honestly, I was staying in 1st and 2nd too long before shifting, and not staying it 3rd and 4th long enough before shifting. Those changes made a huge difference for me.
Silicone, the thinking man's duct tape.
cas6969 is offline
post #4 of 19 Old 08-02-2021, 08:17 AM Thread Starter
djm609
I t doesnt matter how i shift, i have tried it just wont go above 50. i am running 31,s
Always wrenching
djm609 is offline
post #5 of 19 Old 08-02-2021, 08:37 AM
EABiker
If the speedometer gear in the transmission has not been changed after going to 31's, you are actually going 55mph when the speedometer reads 50.
Hey, every little bit helps!
EABiker is offline
post #6 of 19 Old 08-02-2021, 09:47 AM
grandboost98
grandboost98's Avatar
Have you done any diagnosing yet? Whens the last time you had a tune up? Brakes dragging? wheel bearings shot? trans/tcase/diff fluids all good? We need a little more info to help you out
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #7 of 19 Old 08-02-2021, 10:07 AM
whodatschrome
You definitely need to find a steeper hill to drive on...i highly recommend a downhill with the 4cyl engine. The steeper the better.
whodatschrome is offline
post #8 of 19 Old 08-02-2021, 11:14 AM Thread Starter
djm609
So back story is, I just picked this thing up 2 weeks ago. first thing i did was change all the fluids. doing a full tune up on it tonight. working on finding a 6 cylinder and trans to swap. Trans sync's are starting to go in 3rd and 4th, so might have to do a rebuild on a turd.
djm609 is offline
post #9 of 19 Old 08-02-2021, 04:45 PM
gutthans
gutthans's Avatar
To my knowledge, there are several possibilities and I'll have to list all of the ones I can think of because you really haven't given out ANY good information:
#1 is too much back pressure from a clogged cat or failing muffler. 1st and 2nd gear are usually OK and the symptoms of power loss start to show in 3rd/4th and 5th is a total loser.
#2 Tire size needing a change of speedo gearing
#3 Tire size too big (31's are about the max for a stock 2.5)
#4 Fuel flow issues from a bad interior fuel filter sock or line trash reducing volume
#5 Bad O2 sensors messing air/fuel ratio up
This IS NOT a COMPLETE list...just the ones I have personally found on my old 2.5
BTW, IF you are having this much trouble diagnosing the current problem, I wouldn't consider a six swap, just go buy a running six jeep and fix it up, your problems are less likely to get worse.
gutthans is offline
post #10 of 19 Old 08-03-2021, 08:21 AM Thread Starter
djm609
thanks for all the advice (even the sarcastic). Little by little i will get it figured out
Always wrenching
djm609 is offline
post #11 of 19 Old 08-03-2021, 01:07 PM
gutthans
gutthans's Avatar
I wasn't being sarcastic....but it is YOUR Jeep so...have at it!
gutthans is offline
post #12 of 19 Old 08-03-2021, 02:41 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
gots 99 problems but my 2.5L ain't one
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #13 of 19 Old 08-03-2021, 10:07 PM
93YJ4FUN
There is a lot of great advice to be had on the forum. The biggest issue is that without a fuller understanding of your Jeep and your capabilities, it's very hard to help and give that information.
If you ask general questions, you'll get general answers that aren't going to be as helpful.
Guthans was correct that it can be a lot of issues. I can think of a dozen myself without being a guru like some of these guys are.
It could be your
Gear ratio
Low compression
Anything that Guthans suggested
Weak fuel delivery
And many others
How comfortable are you with working on cars? You mentioned swapping in a 4.0 and rebuilding a transmission. Are you planning on doing it yourself or having someone else do it?
Better questions, better information, better answers, better results.
People here are willing to give you as much help as they can with what you give them to work with.
I have seen this at work. Good luck on getting it driving better.
93YJ4FUN is offline
post #14 of 19 Old 08-04-2021, 09:05 AM Thread Starter
djm609
I am Very comfortable working on my jeep. I am not a professional mechanic but have been wrenching for over 20 years and have a full shop at my house. i checked compression last night and all good there. i have narrowed it down to the cat. Since it is 25 yrs old and doesnt get inspected it is coming out. T he reason i bought this particular jeep is that the frame is immaculate. not a bit of rust. Very hard to find here in Jersey.
Always wrenching
djm609 is offline
post #15 of 19 Old 08-04-2021, 11:34 AM
93YJ4FUN
Let us know how that goes. Hopefully that'll solve your issue.
93YJ4FUN is offline
