Tummy tuck - JeepForum.com
 11Likes
post #1 of 42 Old 03-11-2019, 12:52 PM Thread Starter
jhrebs
1987 YJ Wrangler
Tummy tuck
I know this has been discussed a lot. Just had a couple questions.
I already have a 1Ē BL, SYE and CV driveshaft. What Iím thinking is install 1Ē MML, cut my rear spring perches and reweld with the proper position.
Do you guys think I have enough room to go completely flat since I still have the stock AX-5 and NP 231? If not I will use 1Ē square stock on the frame and bolt my plate to that.
Iíve also read that a tuck can cause the floor pan to get very hot. Was thinking of maybe installing heat blanket or insulation or something like that underneath.
The hardest part I think will be making my mount for the trans. I saw a nice one somewhere on this forum with bushings and such. Am I missing anything?
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is online now
post #2 of 42 Old 03-11-2019, 01:11 PM
bruinjeeper
bruinjeeper's Avatar
Most everyone who pursues this makes a separate crossmember tranny mount you mentioned.
I know I will when the time comes.
Subscribed. Depending on your setup, u may need to "massage the floor" a bit or perhaps even adjust the clocking on your tcase
There are quite a few write ups and build threads that cover this from point A to B
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #3 of 42 Old 03-11-2019, 03:59 PM Thread Starter
jhrebs
1987 YJ Wrangler
I can use this for my cross member mounting
https://www.barnes4wd.com/Crossmembe...Set_p_112.html
And one of these skid plates.
https://www.barnes4wd.com/Jeep-YJ-2-...ate_p_216.html
https://www.barnes4wd.com/Jeep-YJ-Fl...ate_p_215.html
These are cheaper than I can buy plate and make myself.
Now should I use c-channel or rectangle stock
post #4 of 42 Old 03-11-2019, 04:08 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Your profile says only a 2" lift and 31's. You likely don't need the things you're doing for that small angle. Exactly what problem are you trying to solve?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 42 Old 03-11-2019, 05:28 PM Thread Starter
jhrebs
1987 YJ Wrangler
Guess I should update sorry. Iím now on 33ís, 8.8, total of 4.5Ē lift with BL, shackles and springs. Lunchbox locker.
Iím trying to gain a bit more clearance by doing a tummy tuck.
post #6 of 42 Old 03-11-2019, 05:29 PM
Waternut
Waternut's Avatar
That skid plate from Barnes is pretty cheap. Kinda wish I had gone that route rather than making my own.
The trans crossmember would make things way easier to work on underneath but it's honestly not required and I couldn't come up with a good way to mount mine and still have adequate clearance. I mounted my LS with the way heavier 4L60E automatic directly on my 3/16" skid plate and I just put some poly bushings in between the two so they weren't hard mounted. The corssmember setup you linked is nice because it has the bushings on the side. Either way, the AX-5 on a 1/4" skid is a much beefier setup than what I have and I've slammed into mine several times.
Your crossmember can be made of just about anything. Round tube with a flat mount, rectangular/square tube, and L-angle are all suitable options. Just make sure you reinforce it.
I never ran the AX-5 with a flat skid though so I don't know where you'll run into issues. I do know that I had to grind off a few tabs on the transfer case to get them to clear the body rather than hammering on the tub and my transfer case is within 1/2" of where it was with my 4 cyl and AX-5.
Waternut is offline
post #7 of 42 Old 03-11-2019, 05:44 PM
jmart2119
jmart2119's Avatar
Tummy tuck
I used the Barnes crossmember mounting kit and flat skid with my 2.5/AX5 about 5 years ago and now Iím still using the same setup with my 5.7/4L60E. Itís quality stuff. Iíd definitely recommend the separate crossmember, itís worth it.
I easily fit the AX5 with a flat skid and didnít really run into any clearance issues. I didnít have to cut about 1 1/2Ē out of the body channel where the tcase hit. Thatís about it.
2018 YJ of the Year
YJOTM | Aug'15 | Dec'16 | Jan'18
1989 YJ - 98 5.7L Vortec, 4L60E, NP241, D30+8.8, 5.13's, 35" ProComp MT2's
jmart2119 is online now
post #8 of 42 Old 03-11-2019, 05:45 PM Thread Starter
jhrebs
1987 YJ Wrangler
In order to do this in a step process, do you think I can install the mml prior to other steps? If I unbolt the trans mount and install the mml would I be ok for a little bit? Or would my angles be way off?
post #9 of 42 Old 03-11-2019, 06:07 PM Thread Starter
jhrebs
1987 YJ Wrangler
Found this from MORE
https://mountainoffroad.com/collecti...4-x-120-3-long
post #10 of 42 Old 03-11-2019, 07:38 PM
Waternut
Waternut's Avatar
You can install the MML before you get around to anything else. If anything your driveline angles will be better since raising the engine points the transfer case down towards the axle a bit.
Waternut is offline
post #11 of 42 Old 03-11-2019, 07:45 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
We made a bunch of crossmembers for belly ups out of tube, poly bushings, sleeves, tabs etc. Lots of ways to skin that cat. Several manufacturers copied what we did after we posted pics, or made something so close its not even funny.
Here's an example. One crossmember for the tranny - one for the Atlas.
Joe Dillard is offline
post #12 of 42 Old 03-11-2019, 08:08 PM
TSEJEEPERS
TSEJEEPERS's Avatar
This is my write up when I did it.
http://www.mijc.org/phpBB3/viewtopic...elly+up#p11155
I am still running it.
Yes my floor does get hot, really to the point that you could not go bare footed.
For me the reason I did the belly up was because I was lengthening the wheel base and staying on 36 inch tires.
It does work very well.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #13 of 42 Old 03-12-2019, 05:52 AM
StanF
My swap with the NP231 and AX5:
https://www.jeepforum.com/forum/f12/.../#post15820703
StanF is offline
post #14 of 42 Old 03-12-2019, 12:09 PM Thread Starter
jhrebs
1987 YJ Wrangler
Originally Posted by StanF View Post
That write up is very helpful thank you very much. I like that you used to different size DOM to make sizing more convenient. I was contemplating using C channel so I did not have to drill holes for the transmission mount
post #15 of 42 Old 03-13-2019, 05:52 AM Thread Starter
jhrebs
1987 YJ Wrangler
Tummy tuck
I will be buying my brown dog mml this Friday.
Iím also buying the bushing mounts. Just havenít decided which one. Any suggestions?
https://www.ruffstuffspecialties.com...SABEgKl5fD_BwE
A buddy of mine is saying these options look to be overkill. Too big.
Barnes and MORE have smaller sizes
Engine issues after tummy tuck! arg0413 TJ Wrangler Technical Forum 6 07-06-2018 11:38 AM
Savvy Surfboard tummy tuck hokahay TJ Wrangler Technical Forum 5 05-31-2018 05:07 AM
MML needed for tummy tuck on LJ? vinsanity TJ Wrangler Technical Forum 10 03-24-2018 02:01 PM
Need advice for Tummy Tuck/ MML DavePippin TJ Wrangler Technical Forum 31 01-27-2018 07:55 AM
Tummy Tuck Question-tranny exhaust bracket Slobert TJ Wrangler Technical Forum 8 01-02-2018 09:59 PM
