Travel - JeepForum.com
post #1 of 5 Old 08-21-2019, 02:34 PM Thread Starter
OJack
OJack's Avatar
Travel
Guys, how much up travel and droop can you expect from a set of leaf springs which provide about a 4" lift? I"m a coil spring guy (LJ) but my fathers is a YJ guy and I'm trying to help him out. We live in different states otherwise I would physically do the work to figure it out. I believe he has Rough Country springs. Thanks in advance.
OJack is offline
post #2 of 5 Old 08-21-2019, 03:19 PM
UPStrades
Rough country will probably be the shortest in travel. Old man emu supposedly flexes very very well although its only a 2.5". I had both fyi
UPStrades is offline
post #3 of 5 Old 08-21-2019, 03:21 PM
StanF
Generally speaking, Rough Country has a pretty poor reputation for their leaf springs in this forum. I don't have any first had experience, but there seems to be complaints of a rough ride, etc. In general, 4" leaf springs are stiffer than stock springs (and stiffer than lower lift (2-2.5") springs. The number of leafs in the spring pack will greatly determine how much flex you can get. 4 leafs is about the minimum (for YJs), and I'm guessing the Rough Country springs are only 4 leaf. 5 leaf is very common. Very expensive Deaver or Alcan spring packs will have 8 or 9 leafs, and they will flex very nicely.
What's your goal in asking about droop and up travel? Determine shock length? Determine max tire size? I think you'll need to provide more info to get good answers.
StanF is offline
post #4 of 5 Old 08-21-2019, 08:36 PM Thread Starter
OJack
OJack's Avatar
I am trying to determine shock length. The shocks on there now only have about 2" up travel in the rear, maybe 3" in the front...
OJack is offline
post #5 of 5 Old 08-22-2019, 08:23 AM
StanF
Ideally, flex it out and measure for shocks.
Or take a chance and order some 4" YJ lift shocks - that would probably be good enough, if you are sure that it's a 4" lift. Like these for 3" to 6" lift:
https://www.quadratec.com/products/16116_0055_14.htm
You could also take off the shock and measure it compressed and extended to figure out what you have on there now.
StanF is offline
