Transmission Skid - JeepForum.com
 15Likes
post #1 of 80 Old 02-28-2020, 09:28 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
Transmission Skid
I need to replace my concave stock skid plate. Its between Barnes and UCF. I have to drill the Barnes but the UCF comes pre-drilled. Any thoughts? I dont mind drilling just need to make sure I mark them correctly.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #2 of 80 Old 02-28-2020, 09:33 PM
bruinjeeper
bruinjeeper's Avatar
oh baby am i sub`d!
love when threads pop up on an upcoming venture you plan to tackle in the near future.
Are you going flat across the frame rails or just one which adds more clearance
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #3 of 80 Old 02-28-2020, 09:44 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
Going to get the 2 drop. Im not motivated enough to make a flat plate work.
bruinjeeper likes this.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 80 Old 02-29-2020, 12:53 AM
paulhead
if it works fix it
paulhead's Avatar
THats what I got, the 2" drop from barnes
Trying to weld has honed my grinding skills
paulhead is offline
post #5 of 80 Old 02-29-2020, 07:40 AM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
Was it easy enough to layout the holes and drill?
paulhead likes this.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 80 Old 02-29-2020, 09:31 AM
NHfireLJ
NHfireLJ's Avatar
Love my UCF 2" skid...
I'm running a GR universal trans cross member and therefore had a blank skid and then welded some stiffeners in it...
Might be a consideration... More work but you can drop thee skid for any reason and still have the drivetrain supported..
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #7 of 80 Old 02-29-2020, 03:59 PM
jhrebs
1987 YJ Wrangler
Im going to attempt 0 tummy tuck. Completely flat. I already have an 8.8, SYE, 1 body lift. I have the MML I need to install. I have all the bushing and parts to make my cross member. Just need to buy the plate. Couple questions.
1. Should I go to a 2 BL
2. Can I install the MML prior to any work and still drive normal.
3. Would I need to reweld my rear spring perches for my ds angle?
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #8 of 80 Old 02-29-2020, 05:07 PM
bruinjeeper
1. your call. You can make the tummy tuck work easier with it. The outward appearance of your jeep is subjective. It's also generally agreed upon to not go over 1" BL. But many do without adverse effects.
2. Yes.
3. Most likely yes.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #9 of 80 Old 02-29-2020, 05:27 PM
fishadventure
fishadventure's Avatar
I have a Zero tummy. Huge bennies imho. One of the best mods I’ve done.
I did it by making custom frame brackets to lift the motor; motor is 3* rake, nothing hangs below the frame not even exhaust. Motorcycle fork tube for a crossmember.
I wouldn’t bother with buying a MML. Some of the best solutions don’t come with part numbers.
I used “1-inch” body lift and wouldn’t go taller. I also had to clearance the floor support rail and cut a couple small unnecessary appendages off the tcase. Needed an SYE in my situation.
Go for it. It’s worth it.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #10 of 80 Old 02-29-2020, 05:47 PM
crackedcornish
crackedcornish's Avatar
I went with UCF's aluminum engine and TC skid when I trimmed my YJ's tummy
..got them for my TJ too
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #11 of 80 Old 02-29-2020, 05:58 PM
NHfireLJ
NHfireLJ's Avatar
Agreed w some of the previous comments...
1" BL (or 1.25"
yes MML is helpful
most likely...
I'll say the same thing I said earlier too.... consider a universal trans cross member , More work but you can drop the skid for any reason and still have the drivetrain supported..
SOLD
style intake
NHfireLJ is offline
post #12 of 80 Old 02-29-2020, 07:48 PM
jhrebs
1987 YJ Wrangler
What fenders do you have
jhrebs is offline
post #13 of 80 Old 02-29-2020, 07:50 PM
jhrebs
1987 YJ Wrangler
1" BL (or 1.25"
yes MML is helpful
most likely...
My skid will be independent of the trans mount/cross member.
Thanks everyone
jhrebs is offline
post #14 of 80 Old 02-29-2020, 07:55 PM
paulhead
if it works fix it
paulhead's Avatar
Yeah just dry mount it, figure out where the holes go. I made mine long to leave room for error. I also got the braces plus a 1" section of square tube.
paulhead is offline
post #15 of 80 Old 02-29-2020, 07:58 PM
paulhead
if it works fix it
paulhead's Avatar
Also I have a 1" body lift that saved my Roc Trac Tcase because the thing is bigger than a NP231 and barely cleared.
paulhead is offline
