Tires and Wheels - JeepForum.com
 2Likes
  • 1 Post By cdnwillyg
  • 2 Post By bruinjeeper
  • 1 Post By Crazysjeep
post #1 of 9 Old 07-19-2019, 05:50 PM Thread Starter
ayelander
ayelander's Avatar
Tires and Wheels
Currently running 35x12.5R15LT tires on 15x10 wheels with 3.625" backspacing. Cant turn from stop to stop
so I have to take sharp turns with caution. Any suggestions on things I can do to get full steering back?
93 CTYJ, 350 Chevy, SM465, NP 231J TC, Ford 8.8 Rear, D30 with Chromoly, 4" RE Spring lift, 5/8" Boom, 1" body lift, 35" MT's
ayelander is offline
post #2 of 9 Old 07-19-2019, 06:22 PM
Crazysjeep
Crazysjeep's Avatar
Wheel spacers or different rims
Crazysjeep is offline
post #3 of 9 Old 07-20-2019, 06:34 AM Thread Starter
ayelander
ayelander's Avatar
What wheels would you recommend?
post #4 of 9 Old 07-20-2019, 07:25 AM
cdnwillyg
If you're okay with the turning radius that is available with your setup now the stops can be changed to that so your tires don't hit suspension. They are two bolts that can either be turned out or replaced with longer bolts.
littletoes likes this.
cdnwillyg is offline
post #5 of 9 Old 07-20-2019, 07:58 AM
bruinjeeper
bruinjeeper's Avatar
Any wheels with less backspacing in your lug pattern.
3.25" oughta do it, but you should measure.
Wheel spacers would be your cheapest option.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #6 of 9 Old 07-20-2019, 08:55 AM Thread Starter
ayelander
ayelander's Avatar
Guess I'll order a couple of sets of Spidertrax 1.5"
post #7 of 9 Old 07-20-2019, 07:14 PM
bruinjeeper
that will do it. case closed.
can't wait for November of 2027 when some guy with a new to him YJ pokes around in here and inquires about how these wheel spacers worked out for you.
Siva283 and ayelander like this.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 9 Old 07-20-2019, 11:04 PM
Crazysjeep
Crazysjeep's Avatar
They should come with loctite if not make sure to get some and use it
ayelander likes this.
post #9 of 9 Old 07-22-2019, 06:37 PM
littletoes
Quick question;
Do wheel spacers increase the likelihood of breaking an axle, especially with either a Dana 30 or 35?
littletoes is offline
