Tire pressure - JeepForum.com
 1Likes
  • 1 Post By Boojo35
post #1 of 14 Old 08-04-2020, 02:19 PM Thread Starter
SmashleyTulsa
SmashleyTulsa's Avatar
Tire pressure
What tire pressure are you guys running on the street? 42 inch irok bias. SBC, sm465, np205, 1 ton axles
SmashleyTulsa is offline
post #2 of 14 Old 08-04-2020, 05:03 PM
Chrisnvegas
Chrisnvegas's Avatar
20 psi.
A 3000 lb machine with LT rated tires needs testing (chalk test) to make sure the whole tread is touching the ground.
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #3 of 14 Old 08-04-2020, 05:19 PM
gutthans
gutthans's Avatar
I run 24 lbs. in my 33's...and yea, check for full patch contact...I use the sand footprint instead of chalk, but either seem to do.
gutthans is offline
post #4 of 14 Old 08-04-2020, 06:22 PM
Boojo35
1987 YJ Wrangler
Originally Posted by Chrisnvegas View Post
20 psi.
I would never let the chalk test be the final answer. Come on man..... You live in the desert.... What happened to infrared testing being the final answer?
Chrisnvegas likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #5 of 14 Old 08-04-2020, 07:19 PM
wizekrakr
23 psi in 35 inch Toyo A/T's. 5.3L V8 up front, Dana 489 axles. Had it on a scale the other day and with me and a half tank of gas she weighed 4460 lbs.
wizekrakr is offline
post #6 of 14 Old 08-05-2020, 12:08 AM Thread Starter
SmashleyTulsa
Ok thank you guys.. I should probably hit some scales and check my weight as well
post #7 of 14 Old 08-05-2020, 12:22 AM
timatoe
timatoe's Avatar
25
timatoe is offline
post #8 of 14 Old 08-05-2020, 06:36 AM
Waternut
Waternut's Avatar
Yeah I've been meaning to hit the scales with my Jeep as well. Bias ply tires have stiffer sidewalls than radials and you're likely going to need to run lower pressures than your friend on radials to get a similar tire squish. I run 38.5x14.5x15 bias ply TSL's and I have to run them at an almost worrying pressure. On the street at about 16-18 psi, I've got roughly a 75% contact patch on the tire at those pressures. I've run 10psi on the street before and honestly feel like it steers and handles better than 16-18psi. On the trail, I run 4 psi up front and 3 psi in the rear. The picture in the grass is 3-4 psi and the picture in my driveway is 16-18 psi.
92875945_10157140912773715_2740020703410520064_o.jpg   116353677_10218298988293041_3114645505790229716_o.jpg
Waternut is offline
post #9 of 14 Old 08-05-2020, 08:44 AM Thread Starter
SmashleyTulsa
I definitely need to get it checked
post #10 of 14 Old 08-05-2020, 10:00 AM
Randonexplosion
Randonexplosion's Avatar
3,980 lbs on 40s and 20 psi feels right to me.
Randonexplosion is offline
post #11 of 14 Old 08-05-2020, 10:55 AM
4Low2G0
4Low2G0's Avatar
93 4.0 AX15 D30 D44 32in BFG I run at 20 PSI
Whats over that next ridge?
4Low2G0 is online now
post #12 of 14 Old 08-05-2020, 10:21 PM Thread Starter
SmashleyTulsa
Okay that's closer to my size and what I was looking for, apparently everybody says 20 so I will go with that
post #13 of 14 Old 08-07-2020, 09:28 AM
Randonexplosion
It would be a good starting point but you will need to fine tune to your setup. My tires are only 12.5" wide.
post #14 of 14 Old 08-08-2020, 09:14 AM Thread Starter
SmashleyTulsa
I'm at 14 wide
