Throttle body question - JeepForum.com
post #1 of 7 Old 08-03-2020, 08:52 PM Thread Starter
JarheadAl
PO installed a 4.0 TB and a spacer on my 2.5. He also lost the cat and installed a header. Will the 4.0TB cause the exhaust to smell rich?
JarheadAl is offline
post #2 of 7 Old 08-03-2020, 08:56 PM
92 Green YJ
92 Green YJ's Avatar
No. That’s probably due to the cat being gone.
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #3 of 7 Old 08-04-2020, 04:50 AM
fishadventure
fishadventure's Avatar
You have a functional 02 sensor, right?
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 7 Old 08-04-2020, 07:46 AM
clsc7777
That's what I tell my inspection station every 2 years. I "lost my cat and put a header and magnaflow on it" lol. Yes it will smell like nauseous vapors though....
clsc7777 is offline
post #5 of 7 Old 08-05-2020, 08:47 AM Thread Starter
JarheadAl
I do have an O2 sensor. How well it functions is TBD. Basically, no cat, bad smell.
post #6 of 7 Old 08-06-2020, 05:38 AM
fishadventure
The throttle body lets air in. The O2 sensor tells the injectors how much fuel to add. The map sensor ‘might‘ play bad tricks just off idle.
In short, if the O2 sensor is working properly the fuel out put should be the same as ‘stock’ with just a bit less intake air charge restriction (potentially better volumetric efficiency). The computer should ‘learn’ how to deal with any map sensor confusion pretty quickly. Probably the only residual if any will be a few milliseconds linger of ‘bog’ when In gear at idle and stomping it to WOT.
post #7 of 7 Old 08-07-2020, 10:18 AM Thread Starter
JarheadAl
Thanks
