JeepForum.com (https://www.jeepforum.com/forum/)
-   YJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f12/)
-   -   Throttle body question (https://www.jeepforum.com/forum/f12/throttle-body-question-4406481/)
JarheadAl 08-03-2020 08:52 PM
PO installed a 4.0 TB and a spacer on my 2.5. He also lost the cat and installed a header. Will the 4.0TB cause the exhaust to smell rich?
92 Green YJ 08-03-2020 08:56 PM
No. That’s probably due to the cat being gone.
fishadventure 08-04-2020 04:50 AM
You have a functional 02 sensor, right?
clsc7777 08-04-2020 07:46 AM
That's what I tell my inspection station every 2 years. I "lost my cat and put a header and magnaflow on it" lol. Yes it will smell like nauseous vapors though....
JarheadAl 08-05-2020 08:47 AM
I do have an O2 sensor. How well it functions is TBD. Basically, no cat, bad smell.
fishadventure 08-06-2020 05:38 AM
The throttle body lets air in. The O2 sensor tells the injectors how much fuel to add. The map sensor ‘might‘ play bad tricks just off idle.
In short, if the O2 sensor is working properly the fuel out put should be the same as ‘stock’ with just a bit less intake air charge restriction (potentially better volumetric efficiency). The computer should ‘learn’ how to deal with any map sensor confusion pretty quickly. Probably the only residual if any will be a few milliseconds linger of ‘bog’ when In gear at idle and stomping it to WOT.
JarheadAl 08-07-2020 10:18 AM
Thanks
The time now is 09:46 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
