Thoughts on how to remove fender flares - JeepForum.com
 1Likes
post #1 of 20 Old 10-25-2021, 07:51 AM Thread Starter
YMFriday
YMFriday's Avatar
So the aftermarket flares on my '92 are in bad shape & I picked up an OEM set. The PO bolted the flares on, but the heads of many of the bolts are partially or fully inside the cut out and I can't seem to get anything on it; sockets or needle-nose vice grips. The picture is one of the less deeply inset bolts. Some are fully inside the cutout.
YMFriday is offline
post #2 of 20 Old 10-25-2021, 09:06 AM
bpounds
bpounds's Avatar
Thin wall socket
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #3 of 20 Old 10-25-2021, 09:26 AM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Or....
Are they plastic or steel? Hard to tell by the photo.
If you have a Dremel, there are certain grinding heads that would be able to make quick work of enlarging those holes if not even a thin walled socket will get to them.
If they are plastic, I'd slit it and rip them off lol. That would give you ample space to get at those bolts
~YJOTM MAY '16, JUL '19, NOV '21~
bruinjeeper is online now
post #4 of 20 Old 10-25-2021, 09:47 AM Thread Starter
YMFriday
YMFriday's Avatar
They are metal. Hadn’t considered a dremel and, honestly, I’ve never even heard of a thin wall socket, but you can bet I’m picking some up.
YMFriday is offline
post #5 of 20 Old 10-25-2021, 06:47 PM
cas6969
cas6969's Avatar
Thin wall socket? (Edit to add, already mentioned above.)
Silicone, the thinking man's duct tape.
cas6969 is offline
post #6 of 20 Old 10-28-2021, 06:03 PM
Boojo35
1987 YJ Wrangler
My 1/4" dr air ratchet and ANY 10MM socket that I have that fits it along with a little controlled aggression from the hands of a career dude...... These are really easy..... and yes..... I still prefer air to electrical tools for most things around a car. I really do. Kinda off topic but one of these fits in tight places, is very quiet and is stronger than electric for a lot less money. I prefer it too my $750 dollar electric Snap-on piece of crap.
ttps://www.jbtools.com/ingersoll-rand-15qmax-3-8-ultra-compact-impactool/?wi=off&gclid=Cj0KCQjwlOmLBhCHARIsAGiJg7mQrC2azpOU FpbQF4EArfTwxeoMXIEa58Us92cHmfBB0e3_rwB127waAjZDEA Lw_wcB
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #7 of 20 Old 10-28-2021, 06:52 PM Thread Starter
YMFriday
YMFriday's Avatar
I really thought this was going to be a 45 minute project until I found these buried guys. When I poke around online, the only thin wall sockets I see are impact sockets. I don’t need all that. I imagine they’ll come out easy if I can get anything on them.
YMFriday is offline
post #8 of 20 Old 10-28-2021, 08:01 PM
shaggyjim
Ive had to get a cheap socket and grind it down before to fit in some tight spots. Put it on a drill and spin it as your grind, works like a charm.
shaggyjim is offline
post #9 of 20 Old 10-28-2021, 09:31 PM
bpounds
bpounds's Avatar
Look at your 1/4 drive socket set. Most of those are fairly thin. Sacrificing a socket to the grinder is good too.
Bill
bpounds is offline
post #10 of 20 Old 10-28-2021, 10:54 PM
xpage
Add large diameter washers before the head of the bolts and put them back on. MOre surface area, should let them sink into the plastic fender as much
xpage is offline
post #11 of 20 Old 10-29-2021, 08:45 AM
mark1305
mark1305's Avatar
+1 on making a thin wall socket on a grinder. BTDT.
And a +1 on more air tools than electric for working on vehicles and stuff. I have 12 air tools mounted in a circle and held vertically in female air hose fittings on a piece of 3/4 marine plywood. And one cordless drill.
Picking up impact sockets to get a thin wall may not be a bad idea as work on the Jeep later may reveal a need for impact driving. DAMHIK.
89 YJ Parts Bin Special titled as 84 CJ7; parts ranging from 1984 -2000; 4.2L with AX-15.
mark1305 is offline
post #12 of 20 Old 10-29-2021, 09:08 AM
Axhammer
Axhammer's Avatar
OP- All of the ideas posted so far should work for removing these bolts. You could also try cutting a slot for a straight blade screwdriver into the bolt head.
Mark- Does your round plywood spin so up you can select the tool of choice? I’m trying to understand your pneumatic tool storage idea, can post a picture? I’m always open to creating better ways to organize & save space.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #13 of 20 Old 10-29-2021, 09:52 AM Thread Starter
YMFriday
YMFriday's Avatar
This was my plan to avoid a headache like this in the future.
YMFriday is offline
post #14 of 20 Old 10-29-2021, 09:53 AM Thread Starter
YMFriday
YMFriday's Avatar
I have impact sockets, but I can’t imagine a thin wall impact is thinner than a 1/4” drive standard socket.
YMFriday is offline
post #15 of 20 Old 10-29-2021, 02:19 PM
bpounds
bpounds's Avatar
Out of curiosity, what size socket is needed? Probably 7/16 or 1/2", but can't really tell.
Hard to believe one of these wouldn't get in there. I think you might have to grind the end of the socket to get rid of the chamfer. But the OD should be okay.
https://www.harborfreight.com/14-in-...saAlfpEALw_wcB
Lastly, "thin wall" and "impact" are an oxymoron.
Bill
bpounds is offline
