Which thermostat? - JeepForum.com
 3Likes
post #1 of 33 Old 08-17-2019, 06:10 PM Thread Starter
BChamberlin
BChamberlin's Avatar
Which thermostat?
Iím looking at Autozoneís site and they literally have a dozen thermostats that fit my 94 YJ 4.0.
How the heck do you choose?
Sent from my iPhone using Tapatalk
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #2 of 33 Old 08-17-2019, 06:20 PM
Fishstic
Fishstic's Avatar
You're best bet would be taking you're faulty one to the AutoZone so they can find the specific model, but to be honest with you, I'd just get the thermostat with the housing assembly, just so you don't have to go back and take out the new one you bought because the housing failed.
Sent from my ONEPLUS A6013 using Tapatalk
Fishstic is offline
post #3 of 33 Old 08-17-2019, 06:21 PM
Fishstic
Fishstic's Avatar
Also looking at the one in a YJ probably almost any thermostat you just saw on the site will fit if you put in your vehicle type in the search credentials, but my first reply still stands.
Fishstic is offline
post #4 of 33 Old 08-17-2019, 08:16 PM
Flyer58
Flyer58's Avatar
Make sure you get one with the small air valve and when you install it be sure that sure valve is located at the top. When filling with the coolant mix be sure you burp out all the air. It may take a while to get all the air out.
Flyer58 is offline
post #5 of 33 Old 08-17-2019, 08:40 PM Thread Starter
BChamberlin
Thanks for the feedback.
1994 Wrangler YJ
2008 Wrangler X
post #6 of 33 Old 08-18-2019, 04:33 AM
mudbug85603
mudbug85603's Avatar
Stant part # 45359 195* T-stat
'98 TJ 5sp Super 35 D30 w/Aussie 5.13 on 33's
'94 YJ 5sp 4.88 Super 35/HP30 w/Aussie on 33's
mudbug85603 is offline
post #7 of 33 Old 08-18-2019, 02:10 PM Thread Starter
BChamberlin
I couldnít find a thermostat at advanced auto or autozone with the air valve. What happens if I use one without?
1994 Wrangler YJ
2008 Wrangler X
post #8 of 33 Old 08-18-2019, 02:16 PM
Fishstic
Fishstic's Avatar
I wouldn't try that, if you need the thermostat that bad, then try going physically to the store for an exact match, or find a good used one on eBay and hope they have priority shipping.
Fishstic is offline
post #9 of 33 Old 08-18-2019, 02:17 PM
Fishstic
Fishstic's Avatar
Or get one from Omix-Ada for 13 bucks
Fishstic is offline
post #10 of 33 Old 08-18-2019, 02:27 PM Thread Starter
BChamberlin
Whatís the point of the air valve?
1994 Wrangler YJ
2008 Wrangler X
post #11 of 33 Old 08-18-2019, 02:41 PM
Brad Perryman
Brad Perryman's Avatar
Make sure you get the correct temp for YJ. My 89 YJ 4.2L is a 190 degree.
Brad Perryman is offline
post #12 of 33 Old 08-18-2019, 03:12 PM
Flyer58
Flyer58's Avatar
The Jeep 4.0L had a real bad habit of having big air pockets in the head and block which cause hot spots, overheating, and cracking. That little valve lets air slowly escape so the water pump gets properly primed and doesn't cavitate.
Flyer58 is offline
post #13 of 33 Old 08-18-2019, 04:01 PM
CSP
Drill a small hole in one without it.
Boojo35 and downs like this.
CSP is offline
post #14 of 33 Old 08-18-2019, 04:06 PM
mudbug85603
I gave you the part number to the best suited T-Stat possible for use in a Jeep motor now here's a link to that exact same unit. https://www.amazon.com/Stant-45359-S...gateway&sr=8-1
Forget Autozone and Advance Auto!!!! And I would not put an Omix-Ada anything in or on my Jeeps
post #15 of 33 Old 08-18-2019, 05:04 PM Thread Starter
BChamberlin
Yeah I know and thanks. I still donít see the air valve on it.
1994 Wrangler YJ
2008 Wrangler X
