TH350 to NP231 shifter - JeepForum.com
post #1 of 4 Old 01-17-2016, 10:33 PM Thread Starter
90yjkrawler
To all those running TH350s with NP231s behind, how did you rig up the transfer case shifter? Pictures please or links? I've got the two mated and a Lokar shifter already setup on the TH350. XMSN shifter will end up coming through the floor in the original 5spd location.
Until They All Come Home!
90yjkrawler is offline
post #2 of 4 Old 01-18-2016, 11:31 AM
Randonexplosion
Randonexplosion's Avatar
Take a look at Novak's shifters if you are having trouble making the stock shifter work. I used their SK2X shifter and it worked well, you can make the cable shifter work as well
http://www.novak-adapt.com/catalog/shifters/sk2x/
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #3 of 4 Old 01-18-2016, 10:39 PM Thread Starter
90yjkrawler
The Novak Shifter looks nice. Will it come up in the stock location through the floor? Couldn't find a good picture. Did you use their shift knob or does the factory knob go on.?
post #4 of 4 Old 01-18-2016, 11:01 PM
Randonexplosion
It came up in a good spot with my 5.3/4l60e. It has different mounting positions for height and front to back.
