Temp Gauge not working. - JeepForum.com
post #1 of 20 Old 09-15-2009, 02:54 PM Thread Starter
BigLou
I'm new on here and looking for some help.
My temp gauge is not working so I did some research on here and it seems a common problem is the sending unit. I replaced that and still not working. Moves about a millimeter on start up. I checked and cleaned the ribbon and its all nice and clean. Checked it with a volt meter and its getting power. Should I replace the sensor that's in the thermostat?
Thanks for the help
BigLou is offline
post #2 of 20 Old 09-15-2009, 03:02 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here is where your temp gauge sending unit is. Pull the wire off & ground it while the key is on, the gauge should peg out to "hot" if the wiring is okay. If it works, then you need a sending unit.
The sensor in the T-stat housing only supplies a signal to the ECM, not the gauge.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 20 Old 09-15-2009, 03:12 PM Thread Starter
BigLou
Well I just replaced the sending unit. I tried grounding the wire and the gauge doesnt move. any ideas??
BigLou is offline
post #4 of 20 Old 09-15-2009, 03:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The one in the rear of the cylinder head, like in the pic I posted?
With the key in the "on" position, right?
any ideas??
That leaves the wiring, the ribbon, and the gauge as culprits. Time to start checking circuits, do you have an electrical schematic?
Max
Mean Max is offline
post #5 of 20 Old 09-15-2009, 03:23 PM Thread Starter
BigLou
Key was in the "on" position
And If the Chilton's manual has one they I have one.
BigLou is offline
post #6 of 20 Old 09-15-2009, 03:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
PM sent.
Max
Mean Max is offline
post #7 of 20 Old 10-19-2010, 09:55 AM
jacobAnstett
whats the ribbon?
jacobAnstett is offline
post #8 of 20 Old 10-19-2010, 10:16 AM
Roadyy
Roadyy's Avatar
Originally Posted by jacobAnstett View Post
whats the ribbon?
On the back of the gauge cluster is a circuitry ribbon that runs the power to each gauge.
Roadyy is offline
post #9 of 20 Old 10-23-2010, 06:26 PM
94Wrangler4L
that the same for 4.0?
94Wrangler4L is offline
post #10 of 20 Old 10-23-2010, 08:44 PM
Mark05059
the ribbon is behind the dash inside the jeep... engine size doesnt matter at all.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 20 Old 10-23-2010, 09:43 PM
Billy
Billy's Avatar
2010 WK
Max
i was having the same problem.
the hell sending unit did i replace? lol.
"Life ain't all burritos and strippers, my friend."
Billy is offline
post #12 of 20 Old 10-23-2010, 09:57 PM
guy.griffin
guy.griffin's Avatar
1997 XJ Cherokee
I changed mine because it wasn't working put new sensor in gauge pegged hot, so I thought I got the wrong sensor changed it out again next one didn't do anything so I don't know if I have a bad gauge or wire some where
guy.griffin is offline
post #13 of 20 Old 09-04-2013, 02:36 PM
ManWithTheVan
1987 FSJ Wagoneer
I'm having a problem with this I replaced the sensor on the rear of the block and my guage still doesn't work I've grounded out the wire tht goes to it and it did peg to hot any ideas ? Could the parts store sold me a bad sensor?
87 wagoneer 4.0
ManWithTheVan is offline
post #14 of 20 Old 09-04-2013, 07:18 PM
Old4X
1990 CJ7
You can test the sensor with a multimeter and thermometer .
4.0 COOLANT TEMPERATURE SENSOR: Temperature-to-Resistance Values (Approximate)
212 farenheit 185 ohms
160 farenheit 450 ohms
100 farenheit 1600 ohms
70 farenheit 3400 ohms
40 farenheit 7500 ohms
20 farenheit 13,500 ohms
0 farenheit 25,000 ohms
Early sensors measure about 80 ohms cold to 9 ohms hot. Not sure when the change was made, but resistance on all temp sending units drops as it gets hotter.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #15 of 20 Old 09-05-2013, 06:48 AM
ReDinTX
I had similar problem and the actual solider on the back of the gauge had cracked and so there was an open connection in the circuit. I did a poorman fix because i didnt have my solider iron and has been workin like a champ
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
95 yj temp. gauge not working danlab825 YJ Wrangler Technical Forum 9 08-16-2019 05:58 AM
Temp gauge not working.. SleddinJeeper YJ Wrangler Technical Forum 32 12-06-2008 02:32 PM
temp gauge quit working flyinbrad YJ Wrangler Technical Forum 1 10-09-2008 04:58 PM
Temp Gauge Working Again RCHavok797 YJ Wrangler Technical Forum 21 12-01-2007 07:21 PM
Temp Gauge not working??????? samahi72 YJ Wrangler Technical Forum 4 04-10-2006 11:45 AM
