#$@%@ tach still don't work - JeepForum.com
post #1 of 4 Old 11-27-2009, 04:04 PM Thread Starter
Downhole
#[email protected]%@ tach still don't work
I just purchased a used tach for my 6 cyl, 89 YJ and am still not having any luck. I was reluctant to unplug the old tach before the new one arrived because of doing some damage somewhere "down there" and now that it is apart there is no juice to the plug except for the lights. Anyone have any ideas and could I run a wire direct from the distributor to the tach harness and if so which wire goes where?
Downhole is offline
post #2 of 4 Old 11-28-2009, 08:00 AM
epalmer431
If both tachs are not working then most likely the problem is in your tach pick-up or wire harness. I would get a diagram of the wiring and start at the beginning and follow the path. It can be a pain but starting at the begining will allow you to find where the break in connection is.
I'm not sure on your year and model but my 91 tach receives the engine speed signal from the engine controller pin#43.
Good Luck
Eric S Palmer
epalmer431 is offline
post #3 of 4 Old 11-28-2009, 09:04 AM
dadstoy
dadstoy's Avatar
Are the rest of your guages working? Fuse maybe?
dadstoy is offline
post #4 of 4 Old 11-28-2009, 06:28 PM
timatoe
timatoe's Avatar
Are you still running the stock coil?
timatoe is offline
take out the tach Downhole YJ Wrangler Technical Forum 1 11-16-2009 04:07 PM
Need help with Tach hillie4life YJ Wrangler Technical Forum 0 05-20-2009 01:20 PM
HEI Tach Douglas S. YJ Wrangler Technical Forum 12 09-01-2008 06:58 PM
speedo, tach only work sometimes itsgrim TJ Wrangler Technical Forum 1 06-26-2008 05:05 AM
90 YJ tach atakrator YJ Wrangler Technical Forum 1 03-07-2006 10:18 AM
