Sye kits and Ford 9" Ujoints - JeepForum.com
post #1 of 3 Old 06-02-2020, 03:48 PM Thread Starter
V8FUN
I'm researching parts for the rear. The SYE kit came on the tcase, and I don't know what brand it is, but I believe is a 1310 ujoint. The rear has a bigger yolk. For my swap, I've had it in the back of my mind that I'd be using some sort of off the shelf CV drive line. Now I need to determine the best way to fix the different sizes. My first thought was change the yolk on the SYE to match the Ford, which I think may be a 1330 bigcap(?), but are those available for an unknown SYE kit? I know my kit is not an Advance Adapters piece (and I was told their yolks are for their kits or it's too much preload on the bearing), so maybe I should change the yolk on the rear to 1310, being that I need to order parts for the rear anyway? I've been looking at 3rd member assys, but I didn't pay attention to yolk sizes at the time and need to go check a couple to find the options. Last, I don't think I want to have mismatched ujoints on the drive line do I?
What's the best solution for this set up?
V8FUN is offline
post #2 of 3 Old 06-02-2020, 04:28 PM
Duck Doctor
You don’t need the same Size ujoints On both ends of the driveshaft. My Atlas transfer case uses a 1310 joint and the old D35 was 1330 from the factory. Ditched the D35 and used a 1330 to 1310 conversion joint.
Duck Doctor is offline
post #3 of 3 Old 06-02-2020, 05:31 PM Thread Starter
V8FUN
You are correct DD. I spoke with a shop that has built drive lines for me in the past and he says he makes drive lines with different size ujoints all the time. That makes things easier.
V8FUN is offline
