Suspension Lift Project - JeepForum.com
 1Likes
  • 1 Post By jbolty
post #1 of 14 Old 10-12-2020, 09:48 PM Thread Starter
mikwallace
mikwallace's Avatar
I finally pulled the trigger and ordered a Superlift Suspension lift kit with 3.5” lift. Looks like I’ll re-rig the complete setup of the suspension. I currently have 3” body lift . Picture below. The measurement in the pic shows 2 3/4” because I cut 1/4” off to allow for the rock sliders. I plan on reducing the spacer by 50%, but will see how everything looks first.
The front shackles are boomerang style and are 6”, which yields 1” of lift.
And rear shackles look like homemade? They’re 5 1/2” which yields 3/4” lift.
Should I consider going back to stock length shackles? Or should I keep the front boomerang style and put new boomerangs on the back that will match front shackle lift?
Sent from my iPad using Tapatalk
mikwallace is offline
post #2 of 14 Old 10-13-2020, 05:12 AM
Siva283
Siva283's Avatar
Attachment 3939787
Attachment 3939789
Attachment 3939791
I run one inch boom shackles front and rear. The higher are lift springs need a shackle with more travel since as the compress they get considerably longer.
That body lift though cut that thing way day you really dont want more than an inch and even then thats a good bit of leverage on those mounts
Siva283 is offline
post #3 of 14 Old 10-13-2020, 12:04 PM
cpia84
cpia84's Avatar
I understand you bought the lift kit but how much of the "kit" do you actually need. What shocks does it come with? Personally I would remove the entire body lift and buy a kit that replaces the entire portion, but that is me. Also I would definitely replace those rear shackles. A boom shackle with a center bolt is a good option, you will hear mixed theories with regards to that but the results i have seen and experienced say there isnt an issue using a boom shackle. Also when it comes time to install your new springs and shocks be sure to soak all the bolts for a few days prior, our Jeeps arent spring chickens anymore and some lubrication will always be a great additive.
cpia84 is offline
post #4 of 14 Old 10-13-2020, 12:11 PM Thread Starter
mikwallace
mikwallace's Avatar
When you say 1” boom shackles, I assume you’re talking about 6” shackles which would yield 1” of shackle lift?
Sent from my iPhone using Tapatalk
post #5 of 14 Old 10-13-2020, 12:25 PM Thread Starter
mikwallace
mikwallace's Avatar
Yes the kit is complete with shocks that provide the necessary strut for the lift kit. However, if I have additional lift created by the shackles, will that create problems for the shock full extension? That’s why I’m asking about the shackles. I replaced all suspension bushings, body bushings (including the 3” body lift spacers) about 2 years ago and haven’t wheeled much so the bolt/nut removal won’t be a problem. The reason I went back with the 3” body lift was, at the time I didn’t know what I wanted on it for a lift. That’s why it’s taken so long for me to finally pull the trigger on the suspension lift. I know I’ll cut the body lift about 50%, maybe even more? Back to my original question: what considerations should I make for my shackles setup with the 3.5” suspension lift?
Here’s a link to the kit:
https://superlift.com/3-5in-jeep-lif...rangler/2-door
post #6 of 14 Old 10-13-2020, 12:49 PM
cpia84
cpia84's Avatar
Adding boom shackles is not a negative, if you look at the link you send me, the red YJ has front boom shackles.
Looking at the kit there are some things you wont need. The bushings wont be needed since you got new ones, the trackbar relocation bracket isnt needed because if you haven't yet take out the trackbars, and the same thing goes for the sway bar and links. The bump stops should be good. I would look at a u-bolt flip for the rear at minimum, what rear axle do you have?
To answer your question a 5/8" boom shackle lift will do a lot of good for you. I have the kit from M.O.R.E.
Here are a few pictures of my shackles:
82841c2d-e4ab-4ffa-85b1-f4a2ee4d2316_1573527728526.jpg 20200208-jeep-front-end-complete.jpg
cpia84 is offline
post #7 of 14 Old 10-13-2020, 12:57 PM
bruinjeeper
bruinjeeper's Avatar
Agree with @cpia84 ... we're talking a matter of half an inch to 5/8s. It wont adversely affect your shock collapse or extended lengths too too much.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #8 of 14 Old 10-13-2020, 09:56 PM Thread Starter
mikwallace
mikwallace's Avatar
Attachment 3940001 Attachment 3940003
I’ve the stock axles. And I’m undecided on the track bars and sway bar. A lot has been discussed on this forum reference trac bars and the sway bar. I may keep them for a while, then take them out for comparison.
Will also read more about the U-bolt flip. Is the only advantage is that it keeps the bolts/nuts free from damage due to hitting obstacles?
post #9 of 14 Old 10-14-2020, 04:15 AM
cpia84
cpia84's Avatar
Since you are installing a suspension lift I would go ahead and swap out the rear axle for a 95-01 Ford Explorer 8.8 axle. They are readily available, very affordable, strong and durable axles, especially for a mild to moderate wheeler. It will give you piece of mind when you increase tire size and it just far superior to the Dana 35. Even if you stay primary on the road and go on small trails I would make the swap.
As far as the u-bolt flip yes it protects the bolt threads and nuts from getting damaged. It will cost you maybe $20 for brackets from an early 2000 Chevy truck or suburban and then $20-40 for the squared u-bolts. For piece of mind that is well worth it.
With regards to the sway bars and trac bars, just remove them. Heck do it now. Drive it around and you will feel how the suspension isn’t fighting itself. The trac bar was new on the YJs and for the leaf spring setup we have they are not needed. Same with the sway bars, the Jeep as a whole feels like a better ride. After you’ve tested it for a while and agree about keeping them removed then go ahead and cut off the old brackets. It will give you more room for future mods and will give a more cleaner appearance.
Hope all of that info helps.
cpia84 is offline
post #10 of 14 Old 10-14-2020, 05:45 AM
Siva283
Siva283's Avatar
Correct
Siva283 is offline
post #11 of 14 Old 10-16-2020, 10:07 AM
fishadventure
fishadventure's Avatar
Ubolt flip /may/ stop “thread damage“ but that is just a side effect. Ubolt flips stop you from getting hung up on them off road and is the only practical reason I can think of to do it. That it protects the nuts is secondary
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #12 of 14 Old 10-16-2020, 01:09 PM
bruinjeeper
Well there is always a warm and fuzzy feeling of incorporating junkyard parts into your build as a tertiary reason.
Maybe it's just me.
post #13 of 14 Old 10-16-2020, 01:57 PM
jbolty
jbolty's Avatar
Maybe it's just me.
I go out of my way to include junkyard parts whenever possible. Last count I had stuff from these cars:
AMC
dodge
chevy
gmc
cadillac
jaguar
nissan
gmc
ford
peterbilt
kenworth
pontiac
lincoln
cpia84 likes this.
jbolty is offline
post #14 of 14 Old 10-16-2020, 02:31 PM
bruinjeeper
Maybe it's just me.
AMC
dodge
chevy
gmc
cadillac
jaguar
nissan
gmc
ford
peterbilt
kenworth
pontiac
lincoln
Awesome.line up.
Plus... we're cheap haha.
The only issue up here is the real parts off real vehicles are slim pickings because of the climate. They rotted away years ago
