Stock Leaf Springs - JeepForum.com
post #1 of 28 Old 08-07-2020, 11:15 AM Thread Starter
rpwils
rpwils's Avatar
Stock Leaf Springs
Hi Everyone, I just recently bought a 1995 Jeep and it will need a lot of TLC. I was looking to put stock leaf springs and shocks on but wanted to check with you all on what you recommend. I did not want to get into a lift kit etc. But what pounds and brands would you recommend.
Thanks!
rpwils is offline
post #2 of 28 Old 08-07-2020, 12:01 PM Thread Starter
rpwils
rpwils's Avatar
To add to this question, I see the have regular and heavy duty springs. My jeep is the 4.0, would the heavy duty springs be really rough?
rpwils is offline
post #3 of 28 Old 08-07-2020, 12:24 PM
UPStrades
UPStrades's Avatar
You should account for your setup. Full doors, hardtop, soft top half doors etc. Spring rate should be rated for the weight.
UPStrades is offline
post #4 of 28 Old 08-07-2020, 01:43 PM
jbolty
jbolty's Avatar
what he said ^^
but for stock, zero lift these are decent and fairly cheap. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
or go with old man emu for a 2" lift. you will not have to change anything else except maybe remove the track bars
jbolty is offline
post #5 of 28 Old 08-07-2020, 09:42 PM Thread Starter
rpwils
rpwils's Avatar
any opinion on going with something like this? Complete OME YJ Wrangler Suspensions:
Includes everything listed above except Ubolts and shackles. heavy duty.
rocky-road.com/old-man-emu-yj.html
rpwils is offline
post #6 of 28 Old 08-07-2020, 10:40 PM
UPStrades
UPStrades's Avatar
I love my old man emu kit. Rides way better than rough country that's for sure. Some people say it rides better than stock but im not sure about that because i remember when my yj was stock with monroe shocks, rode pretty decent.
Now my jeep is too soft if I'm being picky. Debating on adding the sway bar to stiffen it up just a tad, or changing out my shackles.
post #7 of 28 Old 08-08-2020, 02:29 AM
Chrisnvegas
Chrisnvegas's Avatar
No sway bar, no shackles. What you are talking about is the very thing shocks do. See if your shocks are even working. Pull the bottom end and see if they are blown.
OME 37R springs are the softest, least lift springs. It will be taller than stock but not enough to change the geometry. The ride will still feel stock but with a more healthy look. You can still run a stock tire size without looking goofy or you can go up in size comfortably.
AVOID the OME shocks unless you like a stiff ride. For shocks I like Skyjacker Hydro 7000. They are a good budget shock for less than half the price of OME Sport shocks.
I also recommend changing the rear ujoints whenever making any changes to the ride height. They wear to a specific ride height and will probably wear faster if you make changes. It could also cause vibration.
Who wants to lose the rear driveshaft on the freeway? I like excitement, but not that kind.
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #8 of 28 Old 08-08-2020, 07:58 AM Thread Starter
rpwils
rpwils's Avatar
Thanks everyone! I was trying to stay away from lifting it but still wanted to upgrade the ride. Do you have any experience with omix-ada springs and shocks?
4wd.com/b/suspension-and-shocks/suspension-components/leaf-springs/stock-height-direct-replacemnt/_/N-cm0hiZ1z0w2cv
rpwils is offline
post #9 of 28 Old 08-08-2020, 08:18 AM
Chrisnvegas
Nope.
OME 37R springs are the softest riding springs I've ever seen. When it comes to springs, from my experience, buy cheap springs, get cheap springs.
You may have a different tolerance for ride quality than me. I've been through 3 sets because of ride quality issues. It doesn't bother everyone like me.
post #10 of 28 Old 08-08-2020, 08:38 AM
Chrisnvegas
I don't mean that ^^ in a condescending way.
We all really do have different ideas on what makes a tolerable ride.
For instance, I LIKE the ride of an old Buick. Many people do not.
However, Jeeps (and trucks) I trail ride with can't keep up with me on trails. My Jeep absorbs bumps very well for a Jeep. It's almost ATV-like. Washboards have almost no effect on my Jeep.
It depends on what you're looking for.
post #11 of 28 Old 08-08-2020, 05:22 PM
UPStrades
UPStrades's Avatar
We've had this discussion before my friend. Im also running skyjacker hydro shocks (1 year old) i just prefer a firmer ride. All this is just temporary since im still sua. The goal is full width soa eventually.
Not to thread hijack but at least the OP can gather more info on the many setups that's possible.
post #12 of 28 Old 08-08-2020, 07:40 PM
kweinstein
Hi Chris,
Do you have any pics with the OME 37R springs? I have stock springs also and 235's Generals. Curious what our ride height looks like.
Thanks,
Ken
kweinstein is offline
post #13 of 28 Old 08-09-2020, 08:08 AM Thread Starter
rpwils
rpwils's Avatar
@Chrisnvegas np, I did not take it as condescending, I really appreciate the advice advice and opinions.
rpwils is offline
post #14 of 28 Old 08-09-2020, 01:41 PM
carlsflh
my 94 with ome 37r and 30x950x15 tires
carlsflh is offline
post #15 of 28 Old 08-09-2020, 07:08 PM Thread Starter
rpwils
rpwils's Avatar
Looks like the ome 37r will raise it 2.5 inches then the shackles will raise it another 1 inch. With just the 2.5 it seems like you have to change out other parts such as adjusting the Transfer case. Does that sound correct? If is stuck with standard springs, any recommendations? And are the heavy duty springs that much better?
rpwils is offline
