starting problems - JeepForum.com
post #1 of 4 Old 09-03-2009, 05:02 PM Thread Starter
wesleyrobbin
Guest
starting problems
we have a 1995 jeep wrangler 4.0 was running shut it off to never start again. have changed every sensor distributer timing chain and gears fuel pump traded out fuel rail and injectors new computer tries to fire but wony any ideas
wesleyrobbin is offline
post #2 of 4 Old 09-03-2009, 05:08 PM
idaholtby
idaholtby's Avatar
Start by checking for codes. If none stored, then figure out if this is spark or fuel related. Have you spark to the plugs? What is the fuel pressure at the rail? With all the work that has already been done, it is even possible that the original problem was fixed, but another was introduced.
idaholtby is offline
post #3 of 4 Old 09-03-2009, 05:13 PM Thread Starter
wesleyrobbin
Guest
havent checked pressure yet but can smell the fuel spark is good what we have done is trade out parts with a 93 cherokee that runs trade one part wrangler doesn't start cherokee does waiting for a friend to check codes interesting thing when i changed the fuel pump there was a 12 inch 2x4 in the tank
post #4 of 4 Old 09-03-2009, 05:27 PM
idaholtby
idaholtby's Avatar
You can check the codes yourself by turning the ign to "On" (do not go to start), then back to "Off" (do not go all the way back to were the key can be removed), then back to "On", "Off", and back to "On". After a couple of seconds, the Check Engine Light will begin to flash a series of codes. 12 will be flash flashflash. 12,33, and 55 are normal. Report back what you find. 2"x4" in the tank....First I ever heard of that one.
starting problems greyscot35 TJ Wrangler Technical Forum 1 07-23-2008 01:25 PM
problems starting... bluetj04 TJ Wrangler Technical Forum 0 06-02-2008 10:41 PM
Problems starting jeeprower YJ Wrangler Technical Forum 2 12-23-2007 09:30 PM
starting problems mikegsp YJ Wrangler Technical Forum 2 08-02-2006 01:58 PM
YJ Starting Problems tennisjon2002 YJ Wrangler Technical Forum 6 03-13-2006 10:06 PM
