Starter nose cone breakage - JeepForum.com
 2Likes
  • 2 Post By Luuca
post #1 of 9 Old 10-27-2021, 03:49 PM Thread Starter
ed4banger
'95 4-banger, AX-5. Pulled the tranny and discovered my Mean Green starter was broken. No idea how long its been like this. Installed new 38# flywheel, clutch and rebuilt tranny, and a new Mean Green starter. My question is about shimming it, guessing breakage was from a lack of a required shim, but none were originally present, and it doesn't make any of the noises which would be signs of the need of a shim as discussed in the shop manual. Don't want to break another. Any thoughts anybody? Thanks
'95 YJ, D44 Fr. w/5.13 RCVs &ARB, 8.8 Rr w/Detroit & 4130 shafts, Atlas II Tcase on 33x12.5x15 TSLs
ed4banger is offline
post #2 of 9 Old 10-27-2021, 05:24 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Was it starting fine before you pulled the tranny?
No odd noises to tip you off? Find that hard to believe
Or was it just sitting for a while? Maybe it was fractured but still in tact and something happened when you pulled the tranny to shatter it?
~YJOTM MAY '16, JUL '19, NOV '21~
bruinjeeper is offline
post #3 of 9 Old 10-27-2021, 06:40 PM Thread Starter
ed4banger
No indication whatsoever that there was an issue. Starter is removed before tranny, nothing would of happened during removal that would have broken it. There was enough dirt on the break to suggest it had been this way for a while.
It never sits, daily driver, but short trips, so starter is used often. Starter been in there maybe two years and less than 2K miles. Pulled tranny to address TO bearing issue.
Going to slip a 1/32 or 1/64"" shim in and see what there is to see I guess.....
post #4 of 9 Old 10-28-2021, 03:03 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
honestly, looks like a mfg defect. Issue with the casting. If it worked as normal without any odd sounds, it may have had the defect from the start and any small impact could have forced it apart. I wonder if the fasteners were loose at some point after install and allowed contact between the housing and the starter?
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #5 of 9 Old 10-28-2021, 03:49 PM Thread Starter
ed4banger
Bolts were tight when I disassembled. You may be right, but i assumed it had to do with installation. Thinking I'll be adding the original OEM starter to my inventory of spare parts I carry.....
post #6 of 9 Old 10-28-2021, 05:49 PM
Boojo35
1987 YJ Wrangler
Or some weird thing with a 10MM socket that dropped somewhere.......
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #7 of 9 Old 10-28-2021, 10:54 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
TWO
get it right TWO 10mm sockets dropped into the bellhousing.
bruinjeeper and YoYjay like this.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #8 of 9 Old 10-31-2021, 09:32 PM
calisk8er1080
calisk8er1080's Avatar
TWO
I dunno about you guys, but it always seems to be that damn E12 socket for me. (I think that's the size? the reverse torx for the two bolts on the top of the bellhousing). Always falls straight into the crank sensor hole. Every. Single. Time.
Ex-professional wrench turner
Professional metal gluer-togetherer
Insta @deathmetalwelder
calisk8er1080 is offline
post #9 of 9 Old 11-02-2021, 11:29 AM
Louie4
Louie4's Avatar
1935 CJ2A
The starter motors for my YJís are about the only thing Iíll get remaníed from big box stores simply because they are so easy to remove and replace. I have had good luck with my current one. I think itís been working fine for at least 8-10 years. I even used it a handful of times to get my jeep out of the road in breakdown situations.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
