starter issue - JeepForum.com
post #1 of 7 Old 06-26-2007, 08:38 PM Thread Starter
jwrangler91
starter issue
okay, i just put in a new (used) motor in my jeep
the people i got it from told me it was out of a 93 YJ (I have a 91)
Now after putting this thing in, judging by the difference in motor mounts etc, we seem to think it is out of a cherokee maybe.
so anyway, I went to try and start the thing just now, and it wouldnt fire. It was a power issue. The wires were right with the starter, and the battery should have been okay but it wouldnt fire. It seemed to jam up
Is it possible that if it is out of a Cherokee taht the starter would be different? Im going to get part numbers from advanced tomorrow but im just wondering if anyone has any ideas.
Thanks
91 YJ- Gone
97 XJ- Gone
99 Grand - Daily Driver
jwrangler91 is offline
post #2 of 7 Old 06-26-2007, 08:47 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
4.0, 2.5?? what motor are we talking about??
The motor mounts should be the same between those years.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 7 Old 06-26-2007, 09:08 PM Thread Starter
jwrangler91
4.0 my bad....but the mounts were different thats why i was under the impression that it came out of a cherokee
91 YJ- Gone
97 XJ- Gone
post #4 of 7 Old 06-26-2007, 09:24 PM
mp3coupe
mp3coupe's Avatar
Is the alternator located towards the bottom of the engine? Is the water pump centered with the radiator?
edit shouldn't be a starter problem
http://www.partsamerica.com/ProductG...rtnumber=16848
mp3coupe is offline
post #5 of 7 Old 06-26-2007, 09:38 PM
mp3coupe
mp3coupe's Avatar
Make sure the battery is charged. Terminals are tight on the battery and ground on the block.
If it doesn't start, put a socket on the crank pulley and see if you can turn the engine over by hand(w/ a ratchet) If it doesn't turn over by hand, drop the start and try again.
mp3coupe is offline
post #6 of 7 Old 06-26-2007, 09:49 PM Thread Starter
jwrangler91
Everythign bolted on (alternator etc.) exactly how it did with the old engine. ITs possible the battery wasnt fully charged but i dont think that was the case. Terminals were tight but i can check the ground to the block tomorrow to make sure it is tight
any ohter possibilities. All it did was click once when i tried to turn it over
91 YJ- Gone
97 XJ- Gone
post #7 of 7 Old 06-27-2007, 06:38 AM
rustywrangler
click once means its prolly the batt. If everything bolted up the same as yours it is out of a YJ. The XJ pully setup is alot different.
Starter Issue Lambo3244 YJ Wrangler Technical Forum 4 11-01-2009 11:59 AM
Starter issue Low_2_Lifted YJ Wrangler Technical Forum 2 04-21-2008 07:04 PM
Starter issue theviper90210 YJ Wrangler Technical Forum 2 07-04-2007 06:16 PM
93 2.5L Starter issue.. yjrush YJ Wrangler Technical Forum 3 06-11-2007 09:33 PM
Starter issue vdubstreets YJ Wrangler Technical Forum 7 05-20-2006 04:58 PM
