Stalled out & won’t start 100 miles after new fuel assembly - Page 3 - JeepForum.com
 4Likes
post #31 of 68 Old 07-31-2021, 09:59 PM
shaggyjim
Did you change the fuel filter and the silly 90 degree soft line that feeds it?
shaggyjim is offline
post #32 of 68 Old 07-31-2021, 10:25 PM
Flyer58
Flyer58's Avatar
Take the rubber line off prior to the filter and see in you're at least getting flow to the filter. Have some flow into a big glass jar to see what it looks like. You may have really bad gas in the tank that plugged the filter.
Flyer58 is offline
post #33 of 68 Old 07-31-2021, 11:08 PM
Jjgator
Jjgator's Avatar
Sorry for getting back so late. Just got mine up and running and was out riding around. My symptoms were it would not start sometimes and it would start sometimes. If it did start then as soon as I turned it off it wouldn’t start. We dropped the tank and began to troubleshoot. With the pump out it would work. Then all of a sudden it would not work. Started messing with the wires and that was it. The wires at the connectors were not working. I would go with what someone else suggested, take the fuel line loose from the fuel filter and make sure your pump stays pumping. If when you turn the key and see if fuel flow. If you can I would move the wire and see if it cuts in and out. That’s how we found it. I hate electrical gremlins.
Jjgator is offline
post #34 of 68 Old 08-01-2021, 07:19 AM Thread Starter
YMFriday
YMFriday's Avatar
Yeas, I did change the filter yesterday. It didn’t change anything, unfortunately. I did notice the feeder line was idiotic.
YMFriday is offline
post #35 of 68 Old 08-01-2021, 08:40 AM
shaggyjim
Right on. Ok next question. When you reinstalled the tank did you pinch the lines that run between the frame and tub?
post #36 of 68 Old 08-01-2021, 10:01 AM Thread Starter
YMFriday
YMFriday's Avatar
I doubt it, only because I’m still getting fuel on the tank side of the filter and when I went to check the pressure I had fuel coming out of the gauge. I’m about to test fuel pressure again now that I have a new set.
YMFriday is offline
post #37 of 68 Old 08-01-2021, 10:47 AM Thread Starter
YMFriday
YMFriday's Avatar
Well, this is why we check. I get about 5 lbs of pressure at the rail when cranking.
YMFriday is offline
post #38 of 68 Old 08-01-2021, 01:26 PM Thread Starter
YMFriday
YMFriday's Avatar
Just checked the pressure at the line going into the fuel filter. Same thing. Zero when turning the key to on, maybe 5 lbs when cranking. Looks like my new fuel assembly was bad. Time to call Quadratec tomorrow and get a replacement. Honestly, considering looking up how hard it is to lift the tub off, because I’ve got 15 gallons in the tank, and it was a monster job the first time.
YMFriday is offline
post #39 of 68 Old 08-01-2021, 02:14 PM Thread Starter
YMFriday
YMFriday's Avatar
https://share.icloud.com/photos/02gn...mbXg3g#Atlanta
So I hit it with some starting fluid & it started, ran for about a minute with a really rough idle. Just prior to this it ran for about a minute, but that time, the engine revved a couple of times without touching the gas. Went up to a little over 2k rpm. This was my “I’m about to pack it in for the day, pray for a miracle” method, and when it stayed running I thought maybe it was just working some air out of the line & a miracle was imminent, since it hadn’t stayed running like that at any point, starting fluid or not. No such luck.
YMFriday is offline
post #40 of 68 Old 08-01-2021, 03:39 PM
93YJ4FUN
If you have a container or another car that can use that gas, get one of these. Makes life easier.
http://www.harborfreight.com/battery...ump-63847.html
Or this if you prefer.
https://www.harborfreight.com/multi-...ump-63144.html
93YJ4FUN is offline
post #41 of 68 Old 08-01-2021, 04:13 PM
shaggyjim
Ok so 5 psi at the pump side of the filter, happened after 100 miles, pump runs and stops. Given the pump builds pressure and shuts off instead of running continuously if I remember correctly from you early post I would think you have a restriction in the line somewhere.
Did you reuse the old in tank filter on the new pump and the old soft lines from the pump to the frame side hard lines?
Did you set the clearance on the new pump off the bottom of the tank?
If it was me I would go get 3-5 feet of 5/16th fuel line and remove the silly elbow from the hard lines feeding the filter install the new fuel line and drain the tank into a gas can, you need to check and see if its dirty.
Anyway you can easily use the pump to drain the tank of fuel if you need to drop it again and see what's going on. To me it sounds like some kind of blockage or restriction.
post #42 of 68 Old 08-01-2021, 05:08 PM Thread Starter
YMFriday
YMFriday's Avatar
So I gave the use-pump-to-drain-the-tank a go, and when I turn the key, nothing. Not even a trickle. So I removed the relay and jumpered it and the pump kicks on, and it’s definitely making sound louder than the normal kick-on noise. So the pump is working, that’s a relief, but I’m not sure where the blockage would be. I attached the line to drain from the metal elbow above the fuel filter intake, and it’s got great flow. So if there’s a blockage it would have to be after the filter, which is brand new, changed yesterday. A bad ground makes sense, but I’m not sure where that would be. In searching around I saw some threads talk about a ground wire knew the E-brake, but not with enough detail for me to actually explore it.
YMFriday is offline
post #43 of 68 Old 08-01-2021, 05:15 PM Thread Starter
YMFriday
YMFriday's Avatar
As I mentioned above, jumpering the relay kicks the pump on with really good flow, but even then it doesn’t register with the pressure gauge. Needle doesn’t move at all. But there is great flow. Filled the 5 gallon can in almost no time.
YMFriday is offline
post #44 of 68 Old 08-01-2021, 05:39 PM
shaggyjim
Does the pump stay on when you had the pressure gauge in the line?
post #45 of 68 Old 08-01-2021, 05:45 PM Thread Starter
YMFriday
YMFriday's Avatar
Yes.
YMFriday is offline
