Spring Bolt Extraction Help - JeepForum.com
 2Likes
  • 2 Post By jbolty
post #1 of 11 Old 05-24-2020, 07:33 AM Thread Starter
04TJ-jeeper
04TJ-jeeper's Avatar
over the last two days I've tried installing my RE 2.5" springs, I got the front on pretty problem free, the rear passenger I got completely unbolted and moved on to the driver, disaster struck soon after. I tried unbolting the frame side spring and the head of the bolt spun off, it looks like the previous owners tried cutting it off but didn't finish the job. instead they decided to glue the bolt head back on with some sort of epoxy, there is still a small collar holding the remainder of the bolt against the frame mount, I tacked the collar to the mount and got the nut to spin loose, ground off my tack weld and tried to knock the bolt out but it's seized through the spring, now i'm at a loss how to get bolt out. suggestions? the only thing I can think of is trying to cut the bolt on the inside of the mount but with the fuel line running right through the area i'm not happy with how many sparks that would throw in the direction.
1987 YJ 4.2 / 1990 YJ 4.2 / 1995 YJ 4.0 / 2014 JKU / 2019 JLU
04TJ-jeeper is offline
post #2 of 11 Old 05-24-2020, 07:50 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Saw Zaw will not make any sparks.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 11 Old 05-24-2020, 07:58 AM Thread Starter
04TJ-jeeper
I was considering that, never cut a grade 8 bolt so wasn't sure if it would even work. i'll give it a shot tomorrow
post #4 of 11 Old 05-24-2020, 08:25 AM
gutthans
gutthans's Avatar
Carbide-tipped high-strength steel-cutting blade for Sawz-All.
Optionally, a BFH on the thread side and a heavy punch tool with BFH on the cut-off side (alternate blows) may dislodge the bolt. Small torch on the eye-loop may help too.
gutthans is offline
post #5 of 11 Old 05-24-2020, 09:32 AM
jbolty
jbolty's Avatar
Sawzall will take forever and good luck getting it to not jump all over. cutoff wheel inside the mount is the only way. sparks are no issue unless there is a fuel leak but if you are worried about it put some wet rags around.
NHfireLJ and 11-11-11 like this.
jbolty is offline
post #6 of 11 Old 05-24-2020, 09:32 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If your really worried about sparks at the fuel line, just tape some cardboard up to protect the line.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #7 of 11 Old 05-24-2020, 09:38 AM
carlsflh
just went through this earler this week . got one out using my ball joint press the other one i had to cut out using both a saws all and a 3" air cut off tool. i was trying to save the bolt so i cut through the spring eye and bushing only to find out that i had bent the bolt with the press .it would been easier and faster to just cut the bolt with the saws all .
carlsflh is offline
post #8 of 11 Old 05-25-2020, 06:10 AM
KARamsay
I had to drive 2 out with an air chipping gun.
It worked pretty well... It took longer than I expected.
KARamsay is offline
post #9 of 11 Old 05-27-2020, 09:31 AM
80cj
80cj's Avatar
1980 CJ5
I've cut the bolt using a sawzall with a high speed steel blade. Go slow and use oil. Slow but less chances of messing up the spring bracket.
80cj is offline
post #10 of 11 Old 05-27-2020, 11:25 PM
Awesome
Awesome's Avatar
I've cut spring bolts with a sawzall. If you use a quality steel-cutting blade (Diablo or Milwaukee), it will go through it like butter. I used the same blade for four bolts.
The 4th 5-seater YJ in the world.
Awesome is offline
post #11 of 11 Old 05-28-2020, 06:44 AM Thread Starter
04TJ-jeeper
my Sawzall didn't have the power to cut through, I ended up getting a 6" cut off disc and got it cut out. lift is installed
