Something Is Amiss! - JeepForum.com
 13Likes
post #1 of 36 Old 07-24-2019, 05:41 PM Thread Starter
ayelander
ayelander's Avatar
Something Is Amiss!
Can't figure this one out. Thought it might be the way the CJ front end was mounted...did not pan out. Measured from the front spring perches and they were exact. Measured from the frame to the ground on a level surface and sure enough it was 1/2" difference. What could possibly be the problem? Bent Frame?20190724_191131_resized-002-.jpg
93 CTYJ, 350 Chevy, SM465, NP 231J TC, Ford 8.8 Rear, D30 with Chromoly, 4" RE Spring lift, 5/8" Boom, 1" body lift, 35" MT's
ayelander is offline
post #2 of 36 Old 07-24-2019, 06:19 PM
timatoe
timatoe's Avatar
Tweaked frame would be the first thing I'd think, but I'd also think if there's a 1/2" difference from side to side you'd see some cracking of something around the round cross tube up front.
timatoe is online now
post #3 of 36 Old 07-24-2019, 06:21 PM Thread Starter
ayelander
ayelander's Avatar
I will check that out.
post #4 of 36 Old 07-25-2019, 12:02 AM
Randonexplosion
Randonexplosion's Avatar
My frame is certainly not square to the ground on all 4 corners. Is it because its 31 years old? Maybe from wheeling it hard? I dunno. I think i was between 1/4 and 1/2" different on the front with the driver side being lower. It drives you crazy when you are mounting up coilovers/ORIs
Sent from my SM-N960U using Tapatalk
NHfireLJ and ayelander like this.
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #5 of 36 Old 07-25-2019, 02:41 PM
TSEJEEPERS
TSEJEEPERS's Avatar
Not sure but I wonder if your trac bar might have something to do with it.
Maybe the extension is not long enough? Try unbolting it and see if it makes a difference. Then unbolt the other side and take it off and throw it away.
Since it is one of those fancy telescoping ones, I guess you could do what ever you do to make it telescope. Then throw it away.
Awesome, bruinjeeper and jmart2119 like this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 36 Old 07-25-2019, 04:35 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
holy smokes batman!
it's busy under there! shiny. but busy!
littletoes likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #7 of 36 Old 07-25-2019, 07:56 PM
Azhunter1
Azhunter1's Avatar
Check to make sure the spring hanger on the back end of the spring isn't wore out. That could cause the sagging. For what it worth, my neighbor wrote a book titled Somethings amiss by Dave Benneman.
Azhunter1 is offline
post #8 of 36 Old 07-25-2019, 08:29 PM Thread Starter
ayelander
ayelander's Avatar
I choose to ignore this comment.
post #9 of 36 Old 07-25-2019, 10:00 PM
Mechman71
Your p/s spring looks to be a bit flatter than the d/s. It could be a trick of perspective, or maybe my eyes are getting old, but it looks like they don't have the same arch.
'89 YJ "Night Eagle" 4.2 5spd, Spinnaker blue/grey, hard top and doors, mostly stock and RUST FREE!!
Mechman71 is offline
post #10 of 36 Old 07-25-2019, 10:26 PM
bruinjeeper
then we figured out what's 'Amiss' - haven't we?
post #11 of 36 Old 07-26-2019, 05:32 AM
fishadventure
fishadventure's Avatar
For one the CJ front end has to be installed with a fully engaged mind in a little body English to level up to the frame anyway because of the way that it mounts. I know this because I did it.
Secondly it appears that your R shackle hanger doesn’t match the height of the L one in relation to the bumper. So there’s a visual compensator that isn’t helping.
3rd, if when you fab’d up everything you weren’t true flat (each corner supported in the same plane dead level as determined by a laser or other method) small discrepancies and past tweaks/events can amplify when on a different surface. If you can level out some pads under the tires the you can measure frame, body, fender mounts, etc and find the “problem.”
Incidentally, on fenders: a 1/8” tweak where fender mounts to body can be 1/2”+ at the front lips. I had to adjust my fenders with hammer and dolly at body bolt vertical, and then shimmy the radiator shell up a squeak on one side for a visual ‘level.’
ayelander likes this.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #12 of 36 Old 07-26-2019, 05:55 AM Thread Starter
ayelander
ayelander's Avatar
For what its worth, springs, bushings, shocks, and yes the tele track bar are all brand new. I replaced everything because of the visual thing thinking the PO springs were sagging (RC's kit). Same effect after all the work.
post #13 of 36 Old 07-26-2019, 08:23 AM
Awesome
Awesome's Avatar
Either your bumper or your front clip looks off. Like something's tweaked.
But have you checked the simplest part? The tires? Measure them.
The 4th 5-seater YJ in the world.
Awesome is offline
post #14 of 36 Old 07-26-2019, 08:32 AM
Awesome
Awesome's Avatar
Weird... I already posted this and it didn't show up.
Have you checked your tires? That'd be the first place I'd check. Measure them out.
Your front clip doesn't look like it lines up with your bumper.
Awesome is offline
post #15 of 36 Old 07-26-2019, 11:32 AM
fishadventure
Ya. If the bumper was level with the shackles (frame?) it would be much closer to ‘right’ looking
