SOA or suspension lift? - Page 5 - JeepForum.com
 13Likes
post #61 of 68 Old 10-15-2020, 11:24 AM
bruinjeeper
bruinjeeper's Avatar
Originally Posted by mrerikd15 View Post
Yeah... I'll get into it soon enough to see. I'm sure the gearing isn't 4.10 though. When installing the lift components am I going to have to shim the axles to fix pinion angles as well?
You should be fine with 2.5" in the springs. But if it were going to be required.... it would only be required in the rear with the spring lift you're discussing.
Each jeep is actually different.
I would guess if you did. Not very much. Unfortunately you wouldnt know until you do it.
Am I recalling things oddly or do I not remember OME springs with a shim already pre-attached to the spring packs?
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #62 of 68 Old 10-15-2020, 03:59 PM Thread Starter
mrerikd15
mrerikd15's Avatar
I don't know, haven't even started searching yet lol. But I'm guessing I'll need them with the 2.5 springs and .5 inch boomers... I'll see if there are any that have them included...
91 Islander 4.0 Auto
mrerikd15 is offline
post #63 of 68 Old 10-16-2020, 06:14 AM
fishadventure
fishadventure's Avatar
Shims are a compromise and I don’t see the point. If you’re doing an 8.8 you’re already putting new perches on: just put them on where you need them. If you’re staying D35 put new perches on.
My opinion anyway
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #64 of 68 Old 10-16-2020, 07:54 AM Thread Starter
mrerikd15
mrerikd15's Avatar
My opinion anyway
Keeping the D35 temporarily so the shims would be needed for now... going to source the 8.8 and get it prepped to swap out. The perches will be properly placed then. Probably going SYE around the same time (hopeefully)
cpia84 likes this.
post #65 of 68 Old 10-16-2020, 09:05 AM
cpia84
cpia84's Avatar
Definitely sounds like a good plan. Depending on the application shims arent bad but when installing the 8.8 and already setting perches might as well eliminate the need for the shims.
When doing your SYE I recommend a Super-short SYE kit. The advantage is added rear driveshaft length as well as a better angle.
Awesome likes this.
cpia84 is offline
post #66 of 68 Old 10-16-2020, 12:32 PM Thread Starter
mrerikd15
mrerikd15's Avatar
Thank you. I have been reading up on the super short SYE.... looks like a worthwhile setup...
post #67 of 68 Old 10-16-2020, 01:07 PM
bruinjeeper
Yep. Shoulda went that route as well.
Life wasnt as green then. *sigh*
post #68 of 68 Old Yesterday, 05:43 PM
Awesome
Awesome's Avatar
Yeah, don't bother with the standard-length SYE. It's pointless. The super-short will eliminate a lot of problems later down the road if you want a tummy tuck. And it's not much more than the regular-length version.
The 4th 5-seater YJ in the world.
Awesome is offline
grandboost98
