Snorkle or stack or what ever its called. - JeepForum.com
post #1 of 13 Old 01-14-2008, 08:05 AM Thread Starter
WindBlown
Guest
Well I think im to the point where my exhaust needs an overhaul so I am wondering if ti be worth my time getting Sa snorkal or stack or whaver you call. ( i am sorry im still learning here) istalled instead and houw much more or less would it be?
WindBlown is offline
post #2 of 13 Old 01-14-2008, 08:28 AM
Michael_94YJ
Well exhaust and snorkel are 2 different things. What's wrong with your exhaust?
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
Michael_94YJ is offline
post #3 of 13 Old 01-14-2008, 08:35 AM Thread Starter
WindBlown
Guest
umm well its severely rusted out and theres hole everywhere doubt it will pass air care next year. it's waking up the neighbours because i goto work at 5 in the morning. well if there two different things how much is a snorkel normally? any ideas? maybe ill google it.
post #4 of 13 Old 01-14-2008, 08:36 AM
tuckinauster
tuckinauster's Avatar
a snorkel is an extension on your intake it keep water out. google ARB safari snorkel. the exhaust stack your prolly thinking of is kinda like the ones that are sometimes fitted to military humvee's. its just an extension of the tail pipe that routes the exhaust over the cab keeping it out of the water. this would probably be unnecessary for a jeep
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #5 of 13 Old 01-14-2008, 08:52 AM
sticksnstonesru
Um...yeah. Unless you waterproof the whole engine bay, the snorkel is worthless. Takes a lot more than breathing air to keep the engine running underwater.
Most people I know running snorkels are just posers anyway. The most water they get is local flooding and then you see them here wondering why their jeep doesn't run right after a big rainstorm .
And....yeah...the whole colder air thing from the outside. Whatever. Between the 2.5 and I6 a CAI is not worth the cost. I don't know anyone who truly needs cold air injection for their wheeling purposes.
Save the $350 for an ARB snorkel and get you a nice new set of gears. It'll take you ten times farther up the trail than a snorkel...
1993 YJ | 2.5L 4 banger | 3.5" Superlift | 1" BL | 4.88's | 33" BFG's |
2007 Toyota Tundra Crew-max | 4x2 | 5.7L | Truxedo Tonneau | 20"'s | Leather | Fully debadged
1999 XJ | stock | 4.0
sticksnstonesru is offline
post #6 of 13 Old 01-14-2008, 09:02 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
an exhaust stack's only usefulness is if you stall while the tail pipe is under water or plan to turn your jeep off with the tailpipe under water.... either way, both instances are rare... they still happen, but i personally don't think it happens enough to justify the cost for most people.
-Erik <--- saw a local yj with his exhaust coming out at the top of the tub... looked HORRIBLE and looked like a burn hazard
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #7 of 13 Old 01-14-2008, 09:05 AM Thread Starter
WindBlown
Guest
yea i was meaning more to get my tail pipe ouut of the water so the air can acaully escape. but if its very rare then maybe its not a good investment but i think the only reason i started on boxing day is i have so many holes in my exhaust system. because i keep getting parked half underwater because the yukon inforn tg fme kep having to get trees taken down to fit.
post #8 of 13 Old 01-14-2008, 09:13 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
unless your new exhaust is 316 ss it will rust too
welcome to the world of steel! even aluminized steel will rust.... as will 304 ss....
when you get your ne exhaust consider painting it with BBQ paint. it will burn off close tot he header and cat, but whatever doesn't burn off will help keep it somewhat protected better than it would be if it was bare metal...
-Erik <--- considers the $75 every 4-5 years for a new exhaust an acceptable maintenance cost
post #9 of 13 Old 01-14-2008, 10:58 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
I disagree to an extent.
For some people, a snorkel is more like cheap insurance against hydrolocking. Granted you may fry some other stuff dunking you nose in too deep but at least you won't have to replace the motor. I know you should "look before you leap" but sometimes a slightly different line through a puddle can have a dire outcome.
As far as needing an ARB, that is probably overkill for all but the most crazy bastards that want to go that deep. A cowl snorkel setup will be plenty for 99% of people to prevent accidental hydrolocking. Actually, moving the stock intake back and centered over the motor will probably be enough for most people but then need to address electronics and extending their vent lines if they like to play in the wet stuff.
As far as cold air intake, I agree, proabably a waste of time unless you run super hot under the hood. Even then, a nice pair of vents will do just fine.
I actually had an ARB snorkel on my XJ. I went as far as to put hood vents and heat shield on the entire intake and it did run a few degrees cooler .... but I didn't notice any more power.
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #10 of 13 Old 01-14-2008, 11:07 AM
pwoens
Guest
ouch!!! that one hurts I agree that 96% of the time MY snorkel is worthless but come spring time wheeling around here and runoff as crazy as it can get, I love the fact I dont have to worry about hydro lock anymore from the factory intake being where it is. I agree the $350 can be spent better elsewhere for most people but for me, it was money well spent considering I got it on a trade deal . And as for rain storms....been in one nasty one and numerous little spats with no issues at all.
As for exhaust stacks.....no reason that I see for ever installing one.....unless you want to make an amphibious YJ......very rare to see a stack.
pwoens is offline
post #11 of 13 Old 01-14-2008, 01:14 PM
sticksnstonesru
Hmmm...hydro-locking...yeah, I can agree to that one. Tell you the truth...anything that damn deep isn't going to get either one of my YJ's through it...with or without a snorkel...ever.
If you're going to hit something that might hydrolock your rig, you need more than a snorkel.
post #12 of 13 Old 01-14-2008, 01:28 PM Thread Starter
WindBlown
Guest
Well I have no clue if id want to make it amphibous but i mean if im getting it redone anyway it could save me some cash i wasnt sure.
post #13 of 13 Old 01-14-2008, 04:09 PM
dand3053
-Erik
I painted my new manifold with 1500 degree header paint and its still lookin good. Might be worth the couple extra bucks a can over BBQ paint if rust worries you that much.
dand3053 is offline
Exhaust Stack?? dglover_8869 JK Wrangler Technical Forum 52 02-22-2011 10:32 PM
Can I stack spacers in the front ? Baotchi JK Wrangler Technical Forum 8 08-02-2007 11:48 AM
center stack dash clips jksr1 JK Wrangler Technical Forum 4 02-17-2007 08:14 PM
03-06 Center Stack RLD831 TJ Wrangler Technical Forum 2 05-18-2006 09:24 PM
Exhaust Stack gosling1 YJ Wrangler Technical Forum 5 06-29-2003 09:40 PM
