Shock recommendations? - JeepForum.com
 4Likes
post #1 of 16 Old 07-06-2019, 04:27 PM Thread Starter
jason280
jason280's Avatar
I have a '94 YJ with Fabtech 4" springs, and its time to replace the shocks. I see most suggestions are for Bilstein 5100/Rubicon Express, but I am curious about correct sizing. The front shock brackets are 25" eye to eye, which should be standard (?) For the lift. The rear, on the other hand, is an 8.8 using lower Explorer spring plates, with the shocks measuring roughly 20.25" eye to eye.
Will I need to order the front and rears separately, or can I go ahead and order shocks set up for a 4/4.5" lift?
jason280 is offline
post #2 of 16 Old 07-07-2019, 09:00 AM
timatoe
timatoe's Avatar
I personally would measure your compressed and extended lengths and buy the Bilsteins that fit those measurements the best. They have an online catalog somewhere on their site that lists the shocks by model and type (eyes or stems etc) and lengths.
timatoe is offline
post #3 of 16 Old 07-07-2019, 05:03 PM
Toastmaster
Bilstein 5100's are nice but also pretty stiff. I rode with a friend who has the Rancho 9000XL shocks and they rode amazingly, nice to be able to adjust the stiffness to your preference.
90' YJ 4.2L Howell EFI, Pacesetter Headers, 35s, Teamrush Ignition, locked D30 & Ford 8.8, 4.88s
Toastmaster is offline
post #4 of 16 Old 07-07-2019, 06:59 PM Thread Starter
jason280
jason280's Avatar
Does Rancho offer anything for a 4" lift? Seems odd, but I couldn't find anything taller than a 2.5" lift on their website...
None
jason280 is offline
post #5 of 16 Old 07-07-2019, 07:31 PM
timatoe
timatoe's Avatar
You get the shocks with the appropriate valving and they won't be stiff.
timatoe is offline
post #6 of 16 Old 07-08-2019, 03:14 AM Thread Starter
jason280
jason280's Avatar
I can definitely say the shocks now on the Jeep are far too stiff, but a lot of its my fault going with the cheapest shocks I could find. Just about anything at this point would be better, but this time I don't mind spending the money.
jason280 is offline
post #7 of 16 Old 07-10-2019, 04:23 PM
bruinjeeper
bruinjeeper's Avatar
how are fabtech springs generally regarded in our YJ community? haven't ever read anything about them as i knew what options i wanted
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #8 of 16 Old 07-11-2019, 12:33 AM
Kolak
Vendor
Kolak's Avatar
Are you currently running stock type mounts with a stem at the top in the front? Or do you have adapters and a loop at the top?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #9 of 16 Old 07-11-2019, 03:36 AM
fishadventure
fishadventure's Avatar
I’m surprised that the Skyjacker H7000 series hasn’t come up yet!
Go to their website - they have all the extended and compressed lengths published there. Your at rest lengths can be used to guesstimate which ones to pick.
Better- especially if you off road any- is to measure or calculate your jeep’s flex and get your extended and compressed lengths, then select the model# from those numbers. Your spring kit “should have” included appropriate-length extended bump stops and your shocks should compress to slightly less than the bump-stop contact length and be slightly longer than the full extended (droop) length. I think it was jeeperdon or opihi ? that posted at some point a very simple way to measure and calculate the right lengths.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #10 of 16 Old 07-12-2019, 05:59 PM Thread Starter
jason280
jason280's Avatar
Stock mounts up front, stem top with loop bottom.
None
jason280 is offline
post #11 of 16 Old 07-13-2019, 12:25 AM
Kolak
Vendor
Kolak's Avatar
The measurements you posted in your first message are from the center of the loop at the bottom to the upper bushing at the top of the front shock correct? And from the center of the loop at the bottom to the center of the loop at the top of the rear shock? And the Jeep is on the ground with the current shocks still installed?
or
Kolak is offline
post #12 of 16 Old 07-13-2019, 09:18 PM Thread Starter
jason280
jason280's Avatar
Yes, that is correct.
None
jason280 is offline
post #13 of 16 Old 07-14-2019, 12:08 AM
Kolak
Vendor
Kolak's Avatar
Great! That will make it very easy to select the proper shock lengths. If you'd like to chat further/get pricing, please PM me here on the forum or email me at [email protected]
I carry Bilstein, Fox, RE, and Rancho for example.
or
Kolak is offline
post #14 of 16 Old 07-14-2019, 09:09 AM Thread Starter
jason280
jason280's Avatar
Finally had a chance to measure spring travel this morning. I put the Jeep on my lift, and measured with the springs fully extended. Up front, I have 27" and the rear is 21.5". I measured without the shocks, and there was no change. I actually had an inch or two of travel left with the front and rear shocks, so they weren't limiting any travel. Up front, I have 6.5" to the bumpstops, so I should be able to figure out my lengths
jason280 is offline
post #15 of 16 Old 07-14-2019, 11:57 AM
Duck Doctor
Not sure I would recommend Bilstein shocks anymore. I’ve had 5100s in four rigs and the quality seems to be going downhill. The most recent set I installed on my SOA YJ started leaking fluid on the first trip out. Never had any issues with these shocks in the past on my TJs or XJ.
Duck Doctor is offline
