Shock orientation - JeepForum.com
 3Likes
post #1 of 22 Old 03-31-2020, 10:11 AM Thread Starter
Waternut
Waternut's Avatar
Shock orientation
So I've read a lot of threads about whether it's ok to mount shocks upside down. Unfortunately, they all seem to deviate from the original question. I don't want to get into can up vs can down or shocks that can be run either way. I'm specifically curious about hydro shocks that have a correct orientation stamped on the can stating which way is up.
Is the shock less effective upside down? Does it not oil properly significantly shortening it's life?
I may be forced to find out for myself because my cans are down and they're getting dented by the brake calipers. There is plenty of clearance under normal steering lock but guessing my shock cans are getting dented pretty bad at the bottom at full bump. Somehow the shocks can still go through their full stroke though.
Waternut is offline
post #2 of 22 Old 03-31-2020, 11:33 AM
ThomasYJ
ThomasYJ's Avatar
I've seen multiple sources state, when mounted upside down the shock can develop an inch or more of travel that is undampened.
Waternut likes this.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #3 of 22 Old 04-01-2020, 05:33 AM
fishadventure
fishadventure's Avatar
Not necessarily so
Depends on the shock. Some are 100% hydraulic and all the valves and orifices are 100% flooded. These can go both ways.
Some gas shocks can go upside down. Some can’t.
Check with the specific manufacturer- no one can answer this generically.
JeeperDon likes this.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 22 Old 04-01-2020, 07:07 AM
RockWoRM
RockWoRM's Avatar
Originally Posted by fishadventure View Post
Not necessarily so
Ditto that. I had a set of Pro comp MX-6 adjustables on the YJ and had them upside down. (yeah, I know, pro comp... but I really liked them. they did well for the $$)
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 22 Old 04-01-2020, 02:07 PM Thread Starter
Waternut
Waternut's Avatar
Ok so sounds like I just need to try it and see honestly... No large company is going to go against their own recommendations when questioned on the phone so I'm not even going to bother with that. Maybe a smaller company where the owners or designer can explain the rationale behind their design...
Waternut is offline
post #6 of 22 Old 04-01-2020, 02:50 PM
jsawduste
2006 YJ Wrangler
My comment was wrong.
jsawduste is offline
post #7 of 22 Old 04-02-2020, 08:20 PM
shaggyjim
NARF!
shaggyjim's Avatar
I was just looking for some new shocks for the front end Waternut and I wanted a can up design for the same reasons you do. Im not having much luck but I did find the Skyjacker M95's that have the can up in the photo. Im going to shoot them and email and make sure that is the way they mount. How is your upside down experiment going?
Jim...
SGT USMC.
......YJOTM June 18......
shaggyjim is offline
post #8 of 22 Old 04-02-2020, 08:50 PM Thread Starter
Waternut
Waternut's Avatar
It's going no where at the moment. I kinda feel like I'm too busy not being busy with the whole quarantine thing to actually do anything at the moment. I'll try to remember to do this when I'm sitting around wondering what I can do tomorrow or this weekend.
ThomasYJ likes this.
Waternut is offline
post #9 of 22 Old 04-02-2020, 09:13 PM
ThomasYJ
ThomasYJ's Avatar
This quarantine has been the best thing yet for my build
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #10 of 22 Old 04-02-2020, 11:40 PM
Awesome
Awesome's Avatar
Bilstein 5100s are can-up in the front and rear.
The 4th 5-seater YJ in the world.
Awesome is offline
post #11 of 22 Old 04-03-2020, 11:42 AM
fishadventure
This quarantine has been the best thing yet for my build <i>
This quarantine has had me exposed to hundreds of ‘the public’ daily.
post #12 of 22 Old 04-03-2020, 01:46 PM
bruinjeeper
bruinjeeper's Avatar
Same.
1000s actually.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #13 of 22 Old 04-03-2020, 07:58 PM Thread Starter
Waternut
Waternut's Avatar
Well I did some limited testing today on my cheap skyjacker shocks. Drove maybe 4-5 miles with it each way. From what I can tell on the short term, upside down still does it's job but it feels like the valving is way lighter on the compression. For me, this is a good thing until I hit a really big dip in the road and then it sounds harsh like I'm hitting bump stops.
A longer trip may cause things to be worse but I need to fix my steering before I take any longer trips.
Waternut is offline
post #14 of 22 Old 04-04-2020, 07:40 AM
JarheadAl
OP,
I'm curious how you will invert your front shocks. The top has a stud and the bottom an eye. Or am I missing something?
JarheadAl is offline
post #15 of 22 Old 04-04-2020, 10:22 AM Thread Starter
Waternut
Waternut's Avatar
Originally Posted by JarheadAl View Post
OP,
Ford shock towers and Skyjacker H7099 shocks with eyelets on both ends. I needed 14" of shock travel and this was the easiest/cheapest way to accomplish that.
Waternut is offline
