Shimmy at 50 mph - JeepForum.com
post #1 of 10 Old 09-07-2019, 06:59 PM Thread Starter
jhrebs
1987 YJ Wrangler
Shimmy at 50 mph
Just noticed this today. Have not done anything to my front end. Iím thinking alignment, ball joints, tie rod ends, wheel bearings?
Not sure how to check these as opposed to just replacing.
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is online now
post #2 of 10 Old 09-07-2019, 10:55 PM
bruinjeeper
bruinjeeper's Avatar
Ball joints: Jack up your front end...one side at a time. Grab the tire in the air at 12 and 6 and push n pull alternating top and bottom check for excessive play.
Tie rods/steering linkage rod ends: grab the bars and shake them real hard. Note any excessive play.
Alternate testing: have someone sit in the driver seat and turn lock to lock. Study the rod ends as this happens keeping note of the pitman arm. Any movement before or at a spot in the rotation where the tires are not turning but the rods are movin? Even a little too much play can mean big effects at highway speeds. Then crawl under your rig and look at the shaft... having your partner turn the wheel, any twisting? (U joints done...).
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #3 of 10 Old 09-07-2019, 10:56 PM
bruinjeeper
Other than this... tire PSI, wheels out of balance... etc.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #4 of 10 Old 09-08-2019, 05:48 AM Thread Starter
jhrebs
1987 YJ Wrangler
Steering shaft or driveshaft?
post #5 of 10 Old 09-08-2019, 05:56 AM
Ross
Do you feel it in you seats or the steering wheel?
It in the steering wheel:
It doesn't hurt to check your ball joints, hubs or TREs but if it is just at that speed my bet is tires. Wear or out of balance.
Rotate them and see if there is any difference.
In the seat maybe drive shaft. Remove them one at a time and see if that makes any difference.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #6 of 10 Old 09-08-2019, 08:41 AM Thread Starter
jhrebs
1987 YJ Wrangler
Shimmy at 50 mph
I feel it slightly in the seat but definitely in the steering wheel and a little bit in the gas pedal. Ball joints are two years old. Moog. But I do rough rock crawling a couple times a year.
Iíll just check it all.
post #7 of 10 Old 09-08-2019, 09:00 AM
bruinjeeper
Steering
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 10 Old 09-08-2019, 09:07 AM Thread Starter
jhrebs
1987 YJ Wrangler
Lower steering shaft is a month old. Brand new.
post #9 of 10 Old 09-08-2019, 01:57 PM
Chrisnvegas
Chrisnvegas's Avatar
You can check alignment at home. (Or a shop, your choice)
You'll need a tape measure, 2x4 with a nail in it, 1/2" wrench and a jack.
Takes me 10 minutes.
https://www.jeepforum.com/forum/f12/...gnment-994928/
A Law repugnant to the Constitution is void. Marbury vs. Madison 1803 I'm talking to you, Virginia...
Chrisnvegas is offline
post #10 of 10 Old 09-10-2019, 06:02 PM
JJ93YJ
Check the bushings on the top and bottoms of your shocks. I had the same problem, the right front shock lower bushing was almost all gone. Never made a sound but let the front get shakey at about 60 indicated(speedo reads slow). Was nothing left but one little piece of rubber.
JJ93YJ is offline
