Shift motor oil change - YJ 1988 - JeepForum.com
 4Likes
  • 2 Post By Sty181
  • 1 Post By timatoe
  • 1 Post By RockWoRM
post #1 of 8 Old 06-22-2021, 12:55 PM Thread Starter
[email protected]
Hello,
is there a trick to replace the oil in the shift motor on the front axle? I just saw an old post, where the housing had a fill plug, which is missing on mine.
I tightened the lower bolts and used a straw to fill the oil form the top, which doesn't seem to be the proper method.
Glad to get any advice.
Dankeschön,
Alex
post #2 of 8 Old 06-22-2021, 01:29 PM
Sty181
the CAD gets it lucubration from the oil in the axle . No need to change or add oil to it. Just service your axle as needed.
Sty181 is offline
post #3 of 8 Old 06-22-2021, 03:50 PM
timatoe
timatoe's Avatar
[email protected] likes this.
timatoe is offline
post #4 of 8 Old 06-22-2021, 07:42 PM
RockWoRM
RockWoRM's Avatar
Be sure not to over fill. There should be the correct amount in the FAQ section. Typically 2-3 pints. IIRC 2.5, but double check.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 8 Old 06-22-2021, 10:09 PM Thread Starter
[email protected]
Thank you very much, I added about 5oz. and will not touch it for the next 30 years.
post #6 of 8 Old 06-23-2021, 03:49 AM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
See you in 30 years when you're posting about issues sourcing Dana 30 internals then
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #7 of 8 Old 06-23-2021, 09:26 AM
jbolty
Administrator
jbolty's Avatar
fill it up to the hole in the diff cover. and if it's never been changed, now would be a good time
jbolty is offline
post #8 of 8 Old 06-23-2021, 04:25 PM
RockWoRM
RockWoRM's Avatar
That's how most of us do it... but sounds like he has a different set up.
A pic would be helpful.
RockWoRM is offline
