Share your tips to quiet your soft top - JeepForum.com
 8Likes
post #1 of 28 Old 07-09-2010, 10:07 AM Thread Starter
Jeremy93yj
I know soft top noise drives us all nuts, so let's share our ideas on how to minimize the chaos. I'll start:
I jammed wadded up toilet paper (didn't have any cotton balls handy) into the snaps on the bows. That helped with the snaps rattling.
I made a thing out of a pool noodle, electrical conduit, a few 2" PVC plumbing T's, and a few carriage bolts and wing nuts. This pops onto the windshield spreader bars between the windshield and rollcage. It takes the slack out of that part of the top and reduces the wretched flapping!
I also riveted on the windshield channel to keep it from coming loose. I drilled the holes a bit larger and used 3/16" short length aluminum rivets.
Best of all, the above modifications cost a total of $10.
bigboss408 likes this.
Jeremy93yj is offline
post #2 of 28 Old 07-09-2010, 10:11 AM
Area.3.Fiftyone
Area.3.Fiftyone's Avatar
Take it off.
bharris68 likes this.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 28 Old 07-09-2010, 10:25 AM Thread Starter
Jeremy93yj
ha I knew I was gonna get that.
post #4 of 28 Old 07-09-2010, 10:51 AM
ZeroGravity
ZeroGravity's Avatar
Originally Posted by IronMaiden View Post
Take it off.
Beat me to it
That PVC bar looks real clean.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #5 of 28 Old 07-09-2010, 11:02 AM
pasinbuy
I will take top off in the hot summer sun, during the rainy season. If you take your top off off during the cold, ice and snowy winter.
I took a piece of flat aluminum 2 inches wide and about about 2.5 feet long. Notched out one end to slip into the strap hold down located in the middle of the windsheild frame on top.
Bowed the piece of aluminum and the other end just lays on my roll bar. No water no flapping. Lots of head room.
pasinbuy is offline
post #6 of 28 Old 07-09-2010, 11:06 AM
jeepinhokie
jeepinhokie's Avatar
i dont have a YJ, but when my TJs top get noisy, i play with the vent controls to "pressurize" the cabin. this helps some.
most of the year, either windows are down or top and doors are off.
HOKIES UNITED!
jeepinhokie is offline
post #7 of 28 Old 07-09-2010, 11:09 AM
pghohnst
Have all the snaps on the soft top!
I was down to 1 snap on the drivers side, 2 on the passenger side (most were missing from the fabric when I bought the Jeep, a few fell out a while later). Going 65-70 on the highway the cloth above the front seats would bow up about 6 inches, and I could see 2 inches of daylight above the doors.
Turns out when you finally replace the rest of the snaps it's a lot quieter.
pghohnst is offline
post #8 of 28 Old 07-09-2010, 02:54 PM
wickedoffroad
1987 YJ Wrangler
Looking at your channel and rivet idea I have one question. If you get a hard top wouldnt you have to grind those off to put on the hardtop?
wickedoffroad is offline
post #9 of 28 Old 07-09-2010, 03:02 PM
ImpactFabWorks
ImpactFabWorks's Avatar
yes he would. I used threaded rivets so that I could remove the header rail when I get my hard top
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #10 of 28 Old 07-09-2010, 03:19 PM Thread Starter
Jeremy93yj
I've never had a hard top, and since I plan on moving south, I never will. I'm glad you brought that up for other people though.
post #11 of 28 Old 07-09-2010, 07:48 PM
ssyj94
I got some foam pipe insulation from home depot and wrapped every bow and bar of my supertop. It quieted down a decent amount and reduced the side window flap.
bharris68 and Awesome like this.
My build:
ssyj94 is offline
post #12 of 28 Old 07-09-2010, 10:20 PM
Djsthe1
Djsthe1's Avatar
pghohnst.. Where did you find the replacement snaps?
Djsthe1 is offline
post #13 of 28 Old 07-09-2010, 10:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Fasnap CLIP34WSD - Fasnap® Upper Door Frame Snaps for 87-95 Jeep® Wrangler YJ - Quadratec
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #14 of 28 Old 07-09-2010, 11:14 PM
pghohnst
Use Max's if you're missing the ones on the rail above the door.
If you're missing the female side (in the cloth itself), I used these:
Dritz Snap Attacher Heavy Duty Kit 7 ct
Dritz Heavy Duty Snaps Size 24 Nickel 7 pc
They're craft snaps, but they've worked so far. You have to get the ones in the first link once - so that you get the tool to attach the snaps. After that you can get the ones from the second link to save a few bucks. I guess you could use any 5/8" snaps if you find another brand cheaper.
pghohnst is offline
post #15 of 28 Old 07-10-2010, 07:18 AM
g8ts
You beat me to it...this really quieted down my side window flaps. Cheap and they don't look bad with the windows off. Might try the noodle support for a long trip good economical idea and I can hang a light of it in the winter
WE'LL PUT A BOOT UP YOUR *[email protected]#!
g8ts is offline
yj , wrangler yj , soft top , noise , loud , quiet
Bestop Soft Top as Quiet as 2003 OEM Style??? TJeep_1999 TJ Wrangler Technical Forum 5 05-29-2009 07:49 AM
Is it possible to quiet down an OEM soft top? EvilM0nkey TJ Wrangler Technical Forum 21 11-19-2008 06:46 PM
2007 soft tops amazingly QUIET Thomas9 JK Wrangler Technical Forum 5 10-24-2006 07:16 AM
Quiet Soft Top: Oxymoron? bgmiller YJ Wrangler Technical Forum 8 10-27-2005 07:36 PM
Quiet down that soft top. Bob K YJ Wrangler Technical Forum 20 10-08-2003 12:52 PM
