Safe-T-Cap another frame repair. - JeepForum.com
 1Likes
  • 1 Post By Whitfimb
post #1 of 13 Old 06-11-2021, 04:59 PM Thread Starter
Whitfimb
Attack of the angry beavers!
Or
Oxy Acetylene is greater than plasma arc
1995 Jeep Wrangler frame (right rear) rust repair. Lower rusty section removed with Oxygen / Acetylene torch and a C-clamped straight edge and then quickly finish dressed with a grinder. SAFE-T-CAP rust repair sleeve heavily modified as I trimmed the over all height by 3/4" and length by 2" to make fitment and welding easier. Then welded in place + POR-15 and ready for another 25 years of service.
20210607_185420_1623451718925.jpg   20210607_184145_1623451750290.jpg   20210607_184233_1623451802327.jpg   20210608_163140_1623451841579.jpg   20210608_165854_1623451870475.jpg
20210608_172218_1623451905676.jpg   20210608_184704_1623451930663.jpg   20210608_184759_1623451954131.jpg   20210608_184743_1623452000155.jpg
Whitfimb is offline
post #2 of 13 Old 06-11-2021, 05:06 PM Thread Starter
Whitfimb
Only a partial tank drop and kept exhaust 100% in place. New rear crossmember installed too since the jeep had been tapped from behind and the original crossmember and bumperette bent up. All in an 3ffort to get the frame in shape for the rear springs so that i can finish out my Old Man Emu 2.5 lift.
Pic 3 & 4 LoL
The 25 year old spring hanger bolts will release from the steel bushing sleeve if you know the magic words.
20210608_193340_1623452511319.jpg   20210608_224542_1623452577003.jpg   20210609_123703_1623452656224.jpg   20210609_123713_1623452672919.jpg
Whitfimb is offline
post #3 of 13 Old 06-11-2021, 05:12 PM Thread Starter
Whitfimb
Being a little vain - I did a full finish grind and flap wheel polish on the safety cap. Its way more beefy then the frame ever was - no fear of altering structural integrity.
Whitfimb is offline
post #4 of 13 Old 06-11-2021, 05:29 PM Thread Starter
Whitfimb
Apparently my 25 year old fuel lines were not into 48 hrs of YOGA. Minor fuel leak now. Not unexpected - but its been awhile. My bulk fuel line in the shop is 25 years old. Times have changed... im checking out the new Nylon fuel line technology and working on finding a better assembly method than 1960's style screw clamps.
Whitfimb is offline
post #5 of 13 Old 06-14-2021, 10:00 AM
Siva283
Siva283's Avatar
Did you seriously just hang the tank by the filler vent and fuel lines?
Siva283 is offline
post #6 of 13 Old 06-14-2021, 03:56 PM Thread Starter
Whitfimb
Fuel fill and vent tubes were disconnected and plugged. Fuel lines were still attached. Yes the lines were pulled taught but most of the weight was supported by the stand and tank propped against the frame. I would have left it hanging by the fill and vent (Not concerned with damaging those lines) but they did not give me enough room. Having turned wrenches for a living, I am very comfortable with the choices I made and the consequences there of. My posting was to share information of how I got it done.
Whitfimb is offline
post #7 of 13 Old 06-15-2021, 05:19 AM
Siva283
Siva283's Avatar
Thats a dangerous game. I lost my wife to a Jeep that caught on fire from damaged fuel lines. Almost lost our daughters too. Sharing infromation is nice but setting a bad example that a newbie might follow can have deadly consequences.
Hopefully they notice "The Leak" that developed after this was done and dont follow that potentially deadly example
Siva283 is offline
post #8 of 13 Old 06-16-2021, 10:48 AM Thread Starter
Whitfimb
Sorry for your loss. I can not imagine the grief.
Whitfimb is offline
post #9 of 13 Old 06-16-2021, 03:18 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Pic 3 & 4 LoL
judging by the looks of the body mount in that 3rd photo, looks like you already found your next project
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #10 of 13 Old 06-17-2021, 03:40 PM Thread Starter
Whitfimb
I'm not sure I see the problem. Can you enlighten me? I have the rear body bolts and mounts off so I can replace the rear crossmember. The in-body nut released and retightened just fine. I removed the above tank body mount bolts also. Doing this allowed me to raise the body slightly and wiggle the rear body bushings out before cutting the crossmember.
Whitfimb is offline
post #11 of 13 Old 06-18-2021, 09:57 AM
bruinjeeper
They just look past their prime is all.
If they are that easy to come out, that's fantastic. Be sure to slather antiseize on those threads before re-installing.
Me? When in Rome. You're that far in... and based on how that one pictured looked, I would replace them. You wont ever have to worry about them again most likely.
post #12 of 13 Old 06-20-2021, 08:29 PM Thread Starter
Whitfimb
6 months ago when I fetched it out of the woods (after being parked for 10 years) the entire Jeep was past its prime. My cousin who sold it to me asked me if the battery would charge up ~ My Response: " Dude, in 3 more months this battery will be old enough to vote!" Slowly but surely ~ I've been rebuilding it.
bruinjeeper likes this.
Whitfimb is offline
post #13 of 13 Old 06-21-2021, 02:19 PM
bruinjeeper
cleaned up real nicely!
