Ruff stuff “the cure” - JeepForum.com
 1Likes
  • 1 Post By Siva283
post #1 of 6 Old 06-11-2019, 05:37 PM Thread Starter
jhrebs
1987 YJ Wrangler
Anyone use or try this? It’s called the cure from Ruff Stuff. It’s suppose to take out that little bit of slop that comes with 1 ton steering
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 6 Old 06-11-2019, 06:41 PM
3VLWMN
whittled it down and put it on my rebuilt front end, haven't had the chance to drive it yet, but just turning the steering in the garage, you can tell it helps. The tie rod moves nice and even, not a bunch of movement like before. Can't wait to get it on the road
3VLWMN is offline
post #3 of 6 Old 06-11-2019, 07:02 PM
Rtank
A friend of mine did this on his XJ and said it worked great.
Rtank is offline
post #4 of 6 Old 06-12-2019, 06:51 AM
Siva283
Siva283's Avatar
I just redid my steering with all MOOG joints. Its tight with no slop. I think people think this works because they put it on with new joints. Its going to wear just the same and in my opinion is a band aid to cover up sloppy rod ends kinda like a steering stabilizer covers up death wobble. But when it comes back it does so with a vengance.
Boojo35 likes this.
Ask me how I know...
Siva283 is offline
post #5 of 6 Old 06-12-2019, 05:43 PM
CSP
It just shims the dead spot you get from tie rod roll. I bought it and it's literally a polyurethane spring bushing that they cut in half with a saw and it's not even a square cut. My advice, find someone with an extra bushing and cut your own.
CSP is offline
post #6 of 6 Old 06-12-2019, 10:01 PM
timatoe
timatoe's Avatar
@Mr.B uses it I believe.
timatoe is offline
