RPMs drop pretty fast. - JeepForum.com
post #1 of 7 Old 05-07-2012, 07:27 PM Thread Starter
bluedaffy
I am just curious as to what dictates how fast the RPMs drop when you let off the throttle? Like any other carbed Jeep owner, over time I have adjusted air/fuel mixture, timing, idle speed yata-yata-yata... And I have noticed that after some changes the rpms would drop slow after revving the engine, and after some changes it would drop fast after revving the engine. Could a lean mix cause a fast drop? Timing?
Just curious as to what can influence the rpm drop speed because as I have things set right now it drops pretty fast (not the fastest I've experienced, but pretty fast) and it makes shifting gears in my manual a little more clunky.
Thanks, Evan
bluedaffy is offline
post #2 of 7 Old 05-08-2012, 06:08 AM
Que89YJ
Bump for the 4.2L crowd.
Que89YJ is offline
post #3 of 7 Old 05-19-2012, 06:08 PM
evanjeep
2011 WK
Where is the air/fuel i think im running to lean it smells like fuel
evanjeep is offline
post #4 of 7 Old 05-19-2012, 06:53 PM
idskot
Smell of fuel means you're running too rich.
And engine wind down is determinant by the engine build / design. My 4.0L's RPMs drop really quickly as well. All the 4.0's I've seen as well as the single 4.2L I've experienced all revved down at the same rate.
idskot is offline
post #5 of 7 Old 05-19-2012, 07:07 PM
darrentrent
bump x3
darrentrent is offline
post #6 of 7 Old 05-19-2012, 07:09 PM
WindsorRenegade
Originally Posted by idskot View Post
. My 4.0L's RPMs drop really quickly as well. .
Same here. I think it's normal, but a carbed engine might be different. I dunno.
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #7 of 7 Old 05-19-2012, 07:24 PM
idskot
No sir. I work with carbed GM-blocked engines (As well as carbed Volvos, unfortunately). They are marine engines but in reality, they're just car engines with a different cooling system. At any rate, they rev down just as quickly as their four-stroked brethren.
idskot is offline
manual transmission , rpm , rpms
RPMs drop colder152000 TJ Wrangler Technical Forum 2 03-08-2011 01:47 PM
RPMs drop gtstricky TJ Wrangler Technical Forum 2 05-17-2010 11:42 AM
my 4.2 rpms dont rise fast ... bcameron1974 YJ Wrangler Technical Forum 10 05-21-2009 11:02 AM
RPMS drop when i hit a bump 186160 TJ Wrangler Technical Forum 4 04-30-2009 07:12 PM
RPMs drop after reserve plyguitar45 YJ Wrangler Technical Forum 1 02-19-2009 10:14 PM
