road kill - JeepForum.com
post #1 of 1 Old 11-21-2019, 05:47 PM Thread Starter
mudd1966
road kill
1993 yj 4.0 5sp does any one know what pin 19 in the ecm is/is it 12 volts /8 volts /5 volts / is it going in or out //// pin 19 is ignition /// pin 3 is battery power pin 9 start/run pins 11 and 12 is ground /no power to coil or cam and crank sensor all fuses are good all grounds are good /checked with test light and ohms meter thank you for the help
mudd1966 is offline
