Replacing ignition switch??? - JeepForum.com
post #1 of 8 Old 06-15-2008, 01:33 PM Thread Starter
onlyinayj89
I need to replace the igition switch and i can see the edge of it but just barley, if anyone knows how to get it off the suggestion would be a big help, i took the plastic dash off by my speedo but that really didnt help, i can't really think of anything esle to do to get to it, thanks for the help.
onlyinayj89 is offline
post #2 of 8 Old 06-15-2008, 02:03 PM
pat8942
pat8942's Avatar
Easiest way is to drop the steering column.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #3 of 8 Old 06-15-2008, 02:25 PM Thread Starter
onlyinayj89
thats what i was wondering, but i didnt think if i took the two bolts out i see holding it, that it would drop,if there even the right ones, thanks for the help
post #4 of 8 Old 06-16-2008, 12:27 AM
timatoe
timatoe's Avatar
There are two 7mm screws on top of the box that hold it onto the column. I replaced mine without dropping the column, but that definately would've made it easier.
timatoe is offline
post #5 of 8 Old 05-22-2014, 05:34 PM
jbeebe
RESSURECTION!!!!!!!
Hey man you need to drop the column or use your go-go-gadget Elf Hands
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #6 of 8 Old 05-22-2014, 06:06 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Originally Posted by jbeebe View Post
RESSURECTION!!!!!!!
Good advice... trying to up your post count?
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #7 of 8 Old 05-22-2014, 06:28 PM
jbeebe
maybe
jbeebe is offline
post #8 of 8 Old 05-22-2014, 06:28 PM
jbeebe
maybe not
jbeebe is offline
Replacing headlight switch with toggle switch? Randy77358 YJ Wrangler Technical Forum 32 07-08-2011 12:15 PM
Replacing 2003 ignition switch jreuscher TJ Wrangler Technical Forum 6 04-03-2011 03:27 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
help replacing the ignition switch... bmxer0122 YJ Wrangler Technical Forum 11 12-14-2008 10:16 AM
Replacing fog light stalk switch with dash mounted switch? Imped TJ Wrangler Technical Forum 7 08-31-2008 12:58 PM
