Radio = Power but no sound - JeepForum.com
 1Likes
  • 1 Post By NHfireLJ
post #1 of 12 Old 06-06-2020, 01:57 PM Thread Starter
WhyJ94
WhyJ94's Avatar
Hey guys,
I've made a lot of progress on my YJ and am now trying to tackle the radio/speakers. The old stock radio from the PO turned on but had no sound. I assumed the radio may have gotten wet or had just the bullet from age or that the speakers died. I purchased an aftermarket radio and a compatible Metra Wiring Harness and crimped/plugged everything in. The radio has power, can switch between all modes (AUX/BT/RADIO/FM/AM) and has no problem connecting to my phone through Blue Tooth. However, no matter what mode I set it on there is zero sound from the speakers..no crackling, static, popping, etc. So I unplugged the speakers from the front dash to take them out of the equation and spliced in some other speakers into the aftermarket radio's wiring for the front speakers. Still no sound at all. In this equation the Jeep is only providing the power and so I should be getting some sound to the speakers I know work fine, yet nothing.
Does anyone have any suggestions on what I may be doing wrong? I matched the wires/colors from the Aftermarket to the Metra Wiring Harness perfectly, so its not a compatibility issue. Any help appreciated.
WhyJ94 is offline
post #2 of 12 Old 06-06-2020, 04:19 PM
91MoneyPit
You could check the continuity between the speaker and the head unit plug to see if there may be a break somewhere in the wires. You could also check the settings of the head unit, I know one that I’ve had in the past had settings for turning on the speakers.
91MoneyPit is offline
post #3 of 12 Old 06-06-2020, 04:36 PM
bruinjeeper
bruinjeeper's Avatar
Really? Outside of the mute button?
Seems absurd right? The head unit has ONE function, why include a setting that would negate it. (Especially when you can just hit mute)
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #4 of 12 Old 06-06-2020, 06:12 PM
91MoneyPit
Depending on the unit, it’s possible. What head unit did you install?
post #5 of 12 Old 06-06-2020, 06:29 PM
91MoneyPit
There’s a big thread with stereo wiring info that may be helpful https://www.jeepforum.com/forum/f12/...topics/2763434
post #6 of 12 Old 06-06-2020, 06:46 PM Thread Starter
WhyJ94
WhyJ94's Avatar
Thanks - I've already read up on that post (good stuff). I bought a relatively cheap 'Dual' Aftermarket Unit from Walmart. I can get some pictures and more info tomorrow when it's light..
WhyJ94 is offline
post #7 of 12 Old 06-06-2020, 06:59 PM
NHfireLJ
NHfireLJ's Avatar
Make sure the antenna is plugged into the back... silly but it'll power on but may not get sound if its not..
timatoe likes this.
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #8 of 12 Old 06-06-2020, 07:07 PM
fishadventure
fishadventure's Avatar
[QUOTE=bruinjeeper;40985135]
That’s not uncommon these days
I use that unit. Worked great up until the last iPhone update, now it isn’t consistent and you can’t play youtube through the speakers anymore.
There is a weird Bluetooth thing I’ve somehow triggered a few times that muted the speakers. The ‘fix’ I discovered is to delete the Bluetooth connection, start over, and reconnect. Viola! Sound!
The head unit is great, the last apple update wrecked it and now I have random issue.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #9 of 12 Old 06-18-2020, 05:04 PM
Hamjam93
Any update? I am having the exact problem in my 93, bought the same Duel from walmart. Taken the dash of today trying to find any breaks but nothing so far.
Hamjam93 is offline
post #10 of 12 Old 06-18-2020, 05:36 PM
fishadventure
Try deleting the Bluetooth connection, hard-booting the phone, and remate. I did that a couple times and then it worked.
post #11 of 12 Old 06-19-2020, 10:15 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
We're sorry to hear that you are experiencing this concern. If you would like any additional assistance, our team is always available via private message!
Alison
JeepCares
JeepCares is offline
post #12 of 12 Old 06-19-2020, 12:03 PM
timatoe
timatoe's Avatar
I second the antenna connection.
timatoe is offline
